steering help
Old Sep 8, 2005 | 11:10 PM
Tani1500's Avatar
Tani1500
Default steering help
alright guys, I need some help with this one. when im on the highway ( 50mph or over ) the steering has about 2 in of pay in it before the steering moves. I dont know what the hell could cause this. I checked everything. the steering shaft from the steering wheel to the pump is moves about an inch back in forth if i turn it by hand. the pitman arm feels tight. the steering stab. is totally shot. what can i do to fix this. it has to go for inspection soon and i want it to pass, ( not to meantion be safe) Like i said, i can really only tell theres something wrong at highway speeds. any help? thanks. [sm=confused06.gif]
Old Sep 8, 2005 | 11:58 PM
Socha_62's Avatar
Socha_62
Default RE: steering help
Not much you can do. Its just crapy rack and pinion steering. Not the most modern, thats for sure
Old Sep 9, 2005 | 01:45 AM
The Burning Rom's Avatar
The Burning Rom
Um....2nd gen Rams don't have rack and pinion. At least none that I've seen.
It probably needs a steering gear/box rebuild.
You can try adjusting it per the TSB here: http://dodgeram.info/tsb/1997/19-10-97.htm
On mine, I adjusted the sector shaft for the steering gear. I snugged the nut down and backed it off 3-5mm of rotation. They're usually off 1.5in from the factory [:'(] It helped a little, but I still have a lot of slop. My steering box will need to be rebuilt when I have some free time.
Old Sep 9, 2005 | 10:58 AM
CopperDesigno's Avatar
CopperDesigno
If you think the steering stabilizer is shot, replace it. A Rancho one is less then $100 and it takes about an hour to do with some basic hand tools. If the bolts are really rusty like mine, hose them down in penetrating oil (wd-40) a couple times prior to removal of the bolts. I had tons of slop and replacing the steering stabilizer cleaned it up a bit and then fixing the track bar did some more, and adjusting the steering gear per Burning Rom's link helped the most.
Old Sep 9, 2005 | 11:42 PM
Tani1500's Avatar
Tani1500
ORIGINAL: CopperDesigno
heres the thing, putting on a new steering stab. is like just putting on a bandaid when you should have stickes. I dont want to fix it with that and have a bigger problem a month down the road because i couldnt tell there was something wrong.
Old Sep 10, 2005 | 11:11 AM
CopperDesigno
Right it would be a bandaid, but it can help gather the steering back up until you get to adjusting the steering geer itself. I actually had to do a little over a full turn on my adjuster screw before IO gained a noticable difference in the steering. But I have 215,000 miles on the original steering geer.
Old Sep 10, 2005 | 11:40 AM
Tani1500's Avatar
Tani1500
does anyone know how much it cost to completely have it rebuild or buy a new one. i mean with my 35in tires. i think a new one may be the way to go if those will be to stress full on it. what do you think
Old Sep 12, 2005 | 02:20 AM
The Burning Rom
IIRC, someone mentioned in a thread on another forum that a rebuild kit for the steering box was around $40 at a parts store.
I was quoted $80 when ordering the invdividual seals/gaskets/etc. from chryslerpartsdirect.com, so I'm not sure what the $40 rebuild kit includes. [>:]
Old Sep 12, 2005 | 05:35 PM
securtis12's Avatar
securtis12
You might want to look into this as a fix have not tried it yet but I am going to soon the wander drives me nuts and mine onlyt has 70k on it.
http://www.solidsteel.ca/DSS.htm
