New member needing help
Old Dec 22, 2012 | 07:21 PM
bowfishingfool09's Avatar
bowfishingfool09
Default New member needing help
I have a 2001 ram 1500 sport. I have no heat blowing thru vents. Checked thermostat, flushed water thru heat core to check for clog, it wasn't. Took off blend door motor and checked plastic interposer ( heatertreater) it wasn't cracked. When I tried to spin the shaft to blend door it's spins back and forth freely. Shouldn't it stop when it shuts off one side?
Old Dec 22, 2012 | 07:25 PM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
Yes, the doors need to stop at some point. Did you check the recirulation mode door? I will move you post to the 2nd Gen Ram section.
Old Dec 22, 2012 | 07:37 PM
bowfishingfool09
Originally Posted by master tech
Welcome to DF
No. How do you Check those. Thanks for moveing this. Still trying to figure out the site
Old Dec 22, 2012 | 08:17 PM
blindsided's Avatar
blindsided
I'd double check the vacuum lines as well.
Old Dec 23, 2012 | 12:41 AM
bowfishingfool09
Under the hood and the back of the switch in the dash looks good.
Old Dec 23, 2012 | 04:55 PM
bowfishingfool09
Took the servo motor off. Have movement in the blend door. Moved to both sides still got cold air. Guess I'm gonna be changeing heater core
