2001 1500 4x4 engine swap advise needed. THANKS
Old Dec 30, 2012 | 11:07 PM
Z400ACDC's Avatar
Z400ACDC
Default 2001 1500 4x4 engine swap advise needed. THANKS
Can I replace my 2001 5.9 with a 2003 5.9? What mods will I have to make? Thanks for the help!!!!
Old Dec 31, 2012 | 12:21 AM
h3lzsn1p3r's Avatar
h3lzsn1p3r
iirc it is plug and play may need to switch over a few sensors though
Old Dec 31, 2012 | 01:23 AM
My360's Avatar
My360
I don't see why not, same motor, should be same everything else.
Old Dec 31, 2012 | 09:15 AM
dhvaughan's Avatar
dhvaughan
i didn't know any vehicle still used a 5.9 magnum in 2003, are you sure? i thought all the dodge's had moved to the 4.7 by 03.
but if so, check that the intake and all sensors are identical. move anything and everything that's not the same from your 01 to the newer motor.
Old Dec 31, 2012 | 09:41 AM
h3lzsn1p3r's Avatar
h3lzsn1p3r
03 was the last year for the engines they just used up what they had left from 02 but i think a few sensors were differnt due to the new computer setup in 03
Old Dec 31, 2012 | 11:56 AM
Z400ACDC's Avatar
Z400ACDC
Thanks for your help!
