stalling problem please help
Old Jan 1, 2013 | 08:31 PM
Arde's Avatar
Arde
Don't worry about that leaky plenum gasket preventing you from getting there. The problems they cause are more of a long slow process. If worse came to worse, such as a plugged cat, you'd just have to remove the O2 sensor to relieve some exhaust backpressure.
Old Jan 1, 2013 | 09:12 PM
You can drive it with a leaking plenum just about forever. Just watch your oil level. Mine was sucking down a quart every 50 miles..... Also, don't step too hard on the go pedal, if you hear the marbles-in-can noise, back off... save your engine.
Where abouts in michigan?
Old Jan 1, 2013 | 10:49 PM
95ramshavedandpolished360's Avatar
New Member
Well i made my own custom y pipe and just deleted the cat and o2 sensor. My cat was originally gutted when i got it. And okay i just wanted to make sure. My luck with this truck has not been very good. I never really get on it i baby all of my vehicles. Im leaving the north branch, lapeer area. And moving to the cheboygan, onaway area
Old Jan 1, 2013 | 10:50 PM
New Member
Thanks for all the help!
Old Jan 1, 2013 | 11:08 PM
Arde's Avatar
Arde
You might want to weld in a bung and put that O2 back in. You'll be running rich without it.
Old Jan 1, 2013 | 11:23 PM
New Member
Okay do i just weld it on the outside or do i cut a hole stick it in and weld it like that?
Old Jan 1, 2013 | 11:27 PM
Arde's Avatar
Arde
Cut a hole. The sensor has to be in the exhaust stream to read it and send info to the PCM.
Old Jan 2, 2013 | 08:24 PM
New Member
Okay will do.
