Help with stuck spark plugs
Old Jan 1, 2013 | 09:12 AM
SilverSS's Avatar
SilverSS
I've always been ok with PB Blaster until I recently bought a used outboard. I've broken 5 bolts so far- even after spraying them for several days, tapping on them, etc. I'm going to have to try the acetone/atf.
Old Jan 1, 2013 | 09:48 AM
Gary-L's Avatar
Gary-L
Veteran: Navy
Another vote for PBlaster, although I've heard good stuff about Kroil.
As far as stubborn plugs, I would run the engine for about 10 minutes to get the plug and head nice and hot. Then, shut off the engine and soak the base of the plug with penetrant. Repeat a few times before attempting to remove the plug.
When removing the plug, back it out until it stops (if it does) or becomes difficult to turn. Stop, apply penetrant and allow it to soak for a while. Repeat soaking a few times and then work the plug (tighten) back into the cylinder before working it back out again.
I always apply a light coat of Anti-Seize to spark plug threads. There are people vehemently opposed to doing so, and I laugh because the Anti types are the ones who'll advise people to coat the plug threads with a light coating of oil.
Old Jan 1, 2013 | 09:49 AM
clipper77's Avatar
clipper77
Acetone/ATF works something powerful.
It is always my last resort before the torch comes out.
Old Jan 1, 2013 | 10:59 AM
AtomicDog's Avatar
AtomicDog
I've had great success with heat and candle wax, as demonstrated here:
Old Jan 1, 2013 | 01:21 PM
crazzywolfie's Avatar
crazzywolfie
that is the problem. most people do not have access to torches like that.
i would have to agree with VW. if you got a stubborn spark plug in a steel head that does not want to come out run the engine to get it hot and it should come out like nothing. i know i had to do that to my dads ford to get the 1 plug out. now i have read that doing this to aluminum heads is not a good idea.
Old Jan 3, 2013 | 09:30 PM
Ziggy2112's Avatar
Ziggy2112
Well.....here it is three days later, and finally SUCCESS!!!! hows that for patience
and for all those wondering........fluids tried:
PB Blaster
Liquid Wrench
CRC Knocerloose
What worked?
Acetone and Tranny fluid!!!!
Thanks for the help everybody! Its nice to know there is people out there willing to share there knowledge.
Old Jan 3, 2013 | 09:34 PM
dhvaughan's Avatar
dhvaughan
congrats and thanks for the follow up. that'll help someone else out.
Old Mar 2, 2013 | 03:17 PM
mitchellcooley's Avatar
mitchellcooley
Yes it will..... I was going to check the plugs on my 01 Ram 1500 and the plugs are so tight it's unbelievable.
Mitch
Old Mar 2, 2013 | 03:28 PM
crazzywolfie
did you try taking them out while the engine was hot? i know i have had to fire up a truck for about 5 minutes before changing plugs just so they would come out nice and easy.
Old Mar 2, 2013 | 06:22 PM
SilverSS's Avatar
SilverSS
Remember put anti-seize on the threads of the new plugs to make them easier to get out later.
