Overdrive Button not working right
Old Jan 5, 2013 | 10:41 PM
bamajay's Avatar
bamajay
Default Overdrive Button not working right
So anyone know what would cause the overdrive off button not to work right? Is it the button its self or is there a sensor that could do this? It will turn off and on, but I have to wiggle the gear shiftier around to make it turn the overdrive off. I have a 99 Ram 1500 with the 318 motor. It has 131,500 miles on it and have never had any trans work done but to have seal replaced.
Old Jan 5, 2013 | 10:55 PM
Chase Lejeune's Avatar
Chase Lejeune
used to have a 96 that wouldnt go into overdrive if i didnt change the tranny oil and put new filters in often enough. id start with that.
Old Jan 5, 2013 | 11:02 PM
dhvaughan's Avatar
dhvaughan
sounds like a broken wire or loose connection in the shift lever. to get a look at the wiring, remove the plastic covers from around the column and look for problems. you need a long skinny torx for the bottom cover. probably a #25. also, that OD button comes off, but i've never had mine off.
welcome to DF, get the service manual here.
https://dodgeforum.com/forum/2nd-gen...load-test.html
