Winch Bumper?
Old Jan 11, 2013 | 01:24 PM
duckslayer5032's Avatar
duckslayer5032
actually look on my profile I have 2 front views on there might help you out
Posted from Dodgeforum.com App for Android
Old Jan 11, 2013 | 02:10 PM
Wh1t3NuKle's Avatar
Wh1t3NuKle
Originally Posted by Edward-T
no i will be running 315's as i have now, not going any larger, mainly wanting the bumper with the full gaurd cause they are so frigging mean looking, i have a bumper mounted(not installed in my sig) brush gaurd on there now.
Where are you located?
Old Jan 11, 2013 | 04:24 PM
dodgetrucker75's Avatar
dodgetrucker75
if you are looking for strength, the runell is the strongest thing i have seen, road armor isnt bad by any means, but the runell is built a little heavier, in either case, i would recomend plating the frame at the mounting holes, otherwise a good pull or push in the correct spot can do some major dammage to the fenders and headlights, i speak from expirence
here is mine
after destroying both my fenders and headlights i added plates to the frame with direct fit holes
and these
Old Jan 11, 2013 | 04:58 PM
duckslayer5032
[quote=dodgetrucker75] if you are looking for strength, the runell is the strongest thing i have seen, road armor isnt bad by any means, but the runell is built a little heavier, in either case, i would recomend plating the frame at the mounting holes, otherwise a good pull or push in the correct spot can do some major dammage to the fenders and headlights, i speak from expirence
I added the plates on the side of the frame and used grade 8 bolts lock washers and nuts
Old Jan 12, 2013 | 10:26 AM
Edward-T's Avatar
Edward-T
i am located in N.C. i have been internet surfing about bumpers all morning and i have found a few companys i like.
Old Jan 12, 2013 | 10:49 AM
duckslayer5032
check out ranch hand bumpers they were gonna be my first choice but got a steal on the road armor
Old Jan 12, 2013 | 11:55 AM
Moochoff's Avatar
Moochoff
When I hit the lotto I will order one from http://www.buckstop.biz/. Good looks and the best prices I found when I looked about a yr ago...
It probably wouldnt even be half the price to make one though lol
Old Jan 12, 2013 | 10:07 PM
Wh1t3NuKle's Avatar
Wh1t3NuKle
Buckstop has been around since I was in high school and saw them on Trucks when Stacy was the host. I think it was TBS network then? A looooong time ago. But then I grew up and puked on the $$$$. lol
+1 lotto!!
Old Jan 12, 2013 | 11:23 PM
III%'s Avatar
III%
I just ordered this one without the brush bar, and a rear one too.
http://www.tacticalarmorgroup.com/TA...9/Default.aspx
It was about $1,400 for both, they are near Atlanta. Nice folks on the phone, very appreciative for your business.
Old Jan 13, 2013 | 12:37 AM
NCC74656's Avatar
NCC74656
i built my own grillguard out of 3/8 steel and welded a 1/2 plate to the front frame cross member to bolt the winch to. spent about 180 bucks total and imo its stronger and better than any winch bumper your going to find. id recomend building one your self. http://imgur.com/a/HrKCa#4
