control arm cam bolt differences
Old Jan 11, 2013 | 01:58 PM
redneck_ram's Avatar
redneck_ram
Default control arm cam bolt differences
hey guys.. small problem.
2001 1500 with a 96 2500 dana 60 axle going into it....
2001 cam bolts are 5/8ths i think? correct me if im wrong!
what bolt size are the cam bolts on the 96 dana 60's?
any help for any and all of the info is greatly appreciated!
Old Jan 11, 2013 | 02:09 PM
Wh1t3NuKle's Avatar
Wh1t3NuKle
You'll find a good link here for absolute parts: https://dodgeforum.com/forum/1825078-post2.html
There is a size difference across the years.
2000-01 LCA bolt is actually 16mm. 5/8" is very close and just easier to use.
Old Jan 11, 2013 | 05:38 PM
redneck_ram
well.... i figured it out. the cam bolts on my 96 axle are 14mm. the LCA to frame bolts are also 14mm.
this puts me in a tough spot. 2001 lca bolts are 16mm, do i order 00-02 2500/3500 control arms, and drill out the bolt holes on the axle, or order 94-97 2500/3500 control arms, and use the smaller bolts.
the only issue that would cause is the frome bolt holes would be 2mm larger than the bolt. would i run into issues?
HELP ME!!
Old Jan 11, 2013 | 05:50 PM
dodgetrucker75's Avatar
dodgetrucker75
your eaisest option would be to get a demmel and open the slots up on the axle to accept the larger bolt, dont put a bolt in a thats too small for the for the hole/bushing on the control arms, thats asking for problems
Old Jan 11, 2013 | 06:45 PM
redneck_ram
yeah i know, bolts could shear off. would be not so good.
im waiting to hear back from top gun customz. gonna see if they will put together some control arms for me utilizing both the 14mm bushing on one end, and the 16mm bushing on the other.
it will be a frankenstein setup, but will work!
Old Jan 11, 2013 | 07:27 PM
dlyter09's Avatar
dlyter09
Why not do an adjustable control arm to where you wont need the cam bolts?
Old Jan 11, 2013 | 07:46 PM
redneck_ram
dont want to spend that kinda money.... well, that, and i dont have the tools to make my own, like whit3 did. or else i would.
Old Jan 11, 2013 | 07:53 PM
dlyter09's Avatar
dlyter09
It was just an idea... I have no clue what it would cost to make them.
Old Jan 11, 2013 | 07:57 PM
redneck_ram
whit3 said it cost him a little over 300 to make all 4 i believe. but i dont have a welder, or else i would!
Old Jan 11, 2013 | 07:58 PM
dlyter09's Avatar
dlyter09
I would think a local Machine shop could do it.. I know my buddies uncle builds them for 3 different sprint cars
