Bad Starts and a P1281
Old Jan 14, 2013 | 01:21 PM
Johnn123's Avatar
Johnn123
Default Bad Starts and a P1281
Hey all, recently my ram has been finding it very hard to start in the morning. It turns over fine just takes a second or two for the motor to start up. It has been quite damp here of late would that be a reason for it to do that? Has never had an issue with this before. Also since I fixed the plenum and installed a 180 degree tstat ive been getting a CEL for P1281 - motor not warm enough when it reaches temperature? Temp guage says its running at 180? Im quite lost any ideas where to start?
Old Jan 14, 2013 | 01:31 PM
Matt Nickerson's Avatar
Matt Nickerson
Don't run a 180 tstat unless you have a proper tune (SCT tuner or such)...Running one without a tune has no benefit, otherwise engineers probably would've settled on the 180. Put a 195* tstat in, preferably not a failsafe.
As far as the starting issue, when's the last time you did a tuneup? How's, the distributor cap look? If it's cracked moisture would love to find it's way in there. Aside from that, troubleshooting ignition, fuel, and compression is where you'll have to start.
Old Jan 14, 2013 | 01:35 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
Worn spark plug wires will cause starting issues in damp and/or humid weather.
Old Jan 14, 2013 | 06:29 PM
Johnn123's Avatar
Johnn123
I have a tune from HemiFever installed. Brand new distributor cap was installed when I did the plenum.
I have brand new spark plug wires I put in when I did the plenum.
Might just take it to my mechanic to look at when he goes to work, he works a dodge dealer and has always done me real good in the past.
Old Jan 15, 2013 | 12:05 AM
gdstock's Avatar
gdstock
What does your fuel pressure look like?
Old Jan 15, 2013 | 05:09 PM
Johnn123's Avatar
Johnn123
How do I check the pressure, just the line?
Old Jan 15, 2013 | 05:16 PM
stewie01's Avatar
stewie01
Need to rent/buy/borrow a fuel pressure tester. Hooks up on the schrader valve on the fuel rail. I think it's on the driver side. Should be around 49 PSI and should build pressure quickly.
Old Jan 15, 2013 | 05:31 PM
dlyter09's Avatar
dlyter09
The code you are getting happens with a few guys who switch to the 180 tstat... As for the starting issues like gdstock and stewie said check the fuel pressure and see where you are at.
