Front end louder than straight pipes!
Old Jan 15, 2013 | 02:04 AM
JaegeRam's Avatar
JaegeRam
Default Front end louder than straight pipes!
Here's the symptoms. They started Sunday out of nowhere. When I turned the wheel left it had a small "creaking" noise and by the end of the day, it was a large noise either way the wheel is turned. Then on Mon I noticed that sitting in it caused considerable squeaking (up and down). Its so loud now that its hard to tell what parts are making the noise. 105,000 m and I'm sure that its all original. WHERE??? do I start?
Old Jan 15, 2013 | 04:34 AM
guzman's Avatar
guzman
Jack the front end up, turn wheels to locate said noise.
Old Jan 15, 2013 | 07:40 AM
Could be: ball joint, tie rods, end links.....where to start is what he ^^ said.
Old Jan 15, 2013 | 06:43 PM
dhvaughan's Avatar
dhvaughan
try this - open the drivers door for a little added leverage and push up/down on the door to rock the cab back and forth. does it sound like this - squeak squeak squeak. if so, follow the auto trans linkage down from the firewall to where it makes a 90* turn to the rear. the nylon bushings on the end of that Z rod are probably dry or worn out. grease them with wheel bearing grease or lithium tube grease.
...or maybe ball joints...
Old Jan 15, 2013 | 06:46 PM
stewie01's Avatar
stewie01
I had the same squeak, it was ball joints on my truck. And man were they shot...
I would look good at the ball joints. If they're original then they are in need of replacement more then likely...
Old Jan 16, 2013 | 12:41 AM
JaegeRam's Avatar
JaegeRam
thanks for the starting point. ball joint upper decimated. ZLooking for a diy righy now
Old Jan 16, 2013 | 06:58 AM
dhvaughan's Avatar
dhvaughan
try this:
https://dodgeforum.com/forum/2nd-gen...placement.html
Old Jan 16, 2013 | 07:11 AM
Ham Bone's Avatar
Ham Bone
My ball joints were totally destroyed and they had to be torched out.
Old Jan 16, 2013 | 10:28 AM
clipper77's Avatar
clipper77
^ Same here.
