Wild Vents
Old Jan 15, 2013 | 03:04 PM
SirHarold's Avatar
SirHarold
Default Wild Vents
My 2001 Dodge Ram has obviously got a vacuum leak because when I'm laying on the gas (ex. When going uphill) the air will automatically transition from the main vents to the defroster. My cruise control doesn't work either. Is this an easy fix?
Thanks,
Old Jan 15, 2013 | 03:13 PM
kejobe's Avatar
kejobe
The fix is usually pretty easy. Its the finding of the vacuum leak that can be a b1tch. Start checking all the vacuum lines under the hood. Also check the check valves. The valves should only flow one way, not both.
Old Jan 15, 2013 | 03:54 PM
Use the search function for "wild vents". Plenty of info there.
Old Jan 15, 2013 | 06:00 PM
The cruise not working would be a big hint where to start looking.... under the battery.
Old Jan 16, 2013 | 10:34 PM
Obiejuankinobie's Avatar
Obiejuankinobie
My Ram the heat stops blowing when I step on the gas. In the summer the air cond stops blowing. Living with it.
Old Jan 19, 2013 | 12:16 PM
c19o's Avatar
c19o
I second that, acid ate away the vacuum hose on my first Dodge.
