audio problem!
Old Jan 15, 2013 | 08:57 PM
KxRideRon125's Avatar
KxRideRon125
Default audio problem!
ok so my right door speakers on my 2000 dodge ram are all staticky unless i tap on the c shape thing the door speaker....i need to know what the heck it is so i can get a new one bc right now i have no right side door speakers Name:  100_0053_zpse9641d10.jpg
Size:  188.4 KB this black C shaped thing
Old Jan 16, 2013 | 04:02 AM
EthanJohns's Avatar
EthanJohns
what it is is a stock 6x9 that i dont even want to begin trying to figure out and explain everything on it. i would just go buy new 6x9s for your doors. it will improve sound qulity also
Old Jan 16, 2013 | 08:27 AM
Ugly1's Avatar
Ugly1
Staticky intermitent speaker is likely due to a corroding/loose connection. Often times a low cost installation uses fast ons (little tabs with a receptacle that slides over the tab). Pulling those things , douching them with contact cleaner then squish the female part pliers to re spring them so they grip the tab better can often times solve the issue permanently. If that doesn't work there is always solder.
Old Jan 17, 2013 | 09:53 PM
KxRideRon125
i have aftermarket speaker an you have to keep this black box thing to hook any speaker up....it wAS the black box...after driving to 6 different junk yards i found another an it worked...they nly stuck them in 99 up i think bc nobody had it in older model rams
Old Jan 17, 2013 | 11:25 PM
h3lzsn1p3r's Avatar
h3lzsn1p3r
they only offered the infinity sound system 99+and you do not need to run the amps or lil black boxes on aftermarket speakers
Old Jan 17, 2013 | 11:42 PM
duckslayer5032's Avatar
duckslayer5032
my 97 larmie has the infinity sounds system from the factory
Posted from Dodgeforum.com App for Android
Old Jan 18, 2013 | 12:23 AM
h3lzsn1p3r's Avatar
h3lzsn1p3r
intresting i didnt know they had it then 2 that kinda makes me wish the original owner ordered it in my 98 much better sound
Old Jan 18, 2013 | 08:54 AM
Ugly1's Avatar
Ugly1
Can't you just pull the old one apart and fix it?
Old Jan 18, 2013 | 10:31 AM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
Yep, Infinity speaker amp is what that guy is.
And yes, my truck has the Infinity speakers.
Old Jan 18, 2013 | 01:33 PM
redheadhunter21's Avatar
redheadhunter21
Just bypass it.... It's old technology and a new set of speakers will sound better
