1996 Dodge Ram 46re transmission shift problem Help Please!
Old Feb 18, 2013 | 10:49 AM
It's supposed to downshift out of O/D when load increases...... Is your TV cable adjusted properly?
While you are in the trans changing that spring, wouldn't hurt to change filter, adjust the bands, and have a look at governor pressure sensor/solenoid. (make sure they aren't sludged up.)
Old Feb 19, 2013 | 06:34 PM
vicsponjr's Avatar
vicsponjr
I just changed the fluid and filter a couple of weeks ago, hoping that would help. previous owner had it overfilled. This is my first Dodge truck and I am learning as I go.
I did not look at the gov sensor/solenoid, or adjust the bands.
I read about the throttle cable and tried to get it off to check it but couldn't see how to get it off. I didn't want to break it so I figured I'd just try to get the fluid level correct then figure out how to get the cable off & check adjustment. Haven't had time to get back out there with this crappy weather we are having.
Old Feb 19, 2013 | 06:44 PM
gdstock's Avatar
gdstock
And if you change the spring, upgrade. Don't just replace with OEM spring. Check sonax website.
Old Feb 21, 2013 | 12:39 AM
vicsponjr's Avatar
vicsponjr
I ordered one through Cascade Transmission. We'll see if it helps when it gets here.
