Squeaking noise while in drive
Old Jan 24, 2013 | 12:27 AM
colinbreckmang's Avatar
colinbreckmang
Default Squeaking noise while in drive
Hey guys,
Just noticed a weird squeaking noise coming from my truck tonight. Its a loud intermittent squeak coming from somewhere under the truck while in drive only and gets faster with the rising rpm's. I put it in reverse and neutral and could not get it to squeak.
Any Ideas what it could be? I'm thinking u-joints on the drive shaft but am unsure how to confirm it.
Thanks
Old Jan 24, 2013 | 12:48 AM
dhvaughan's Avatar
dhvaughan
probably drive shaft u-joints.
park on level ground and block the wheels. trans in neutral and e-brake off so there is no tension on the drive line. grab the u-joints on each side of the cross and twist back and forth. should be no movement. visually check that seals are in place. if no movement, stick a screwdriver through the cross and pry back and forth. still should be no movement. if still no movement, remove driveshaft and flex the joints back and forth checking for dry noise.
Old Jan 24, 2013 | 01:10 AM
jag3rmeiser's Avatar
jag3rmeiser
more then likely your universal joints ( cost five bucks from advance auto) and rather easy to replace. hope that helps man if that doesn't help check your diff and change your fluid and check your gears. or could be possible that your rubber garments in between your leaf have completely rubbed away like mine
Old Jan 25, 2013 | 01:06 AM
colinbreckmang
Got it fixed today. It was the [2] u joints on the rear drive shaft. when i check them they had excessive play in them, thank god I changed em out coulda got stranded somewhere.
thanks for the help
Old Jan 31, 2013 | 09:07 AM
jag3rmeiser
glad you got it fixed! it sucks when you are driving and you u joint cracks believe me lol, had to wait two hour for someone to bring me a new one when i was stuck in 5oclock traffic >.<
Old Jan 31, 2013 | 12:43 PM
petea216's Avatar
petea216
I lost a cup when a clip rotted out and broke off. The worse part was believe it or not, I was on the verge of hitting triple digits when it happened. (Racing another truck) Centrifugal forces threw the stub of the u-joint into the open eye where the cup was pressed into throwing the whole driveshaft out of balance. I got lucky though especially at that speed that it caught like that. Things could have been a lot worse. I was able to actually limp the thing home that way.
