Fuel pump noise?
Old Jan 24, 2013 | 05:22 PM
KxRideRon125's Avatar
KxRideRon125
Default Fuel pump noise?
my fuel pump is making a buzzing sound after been starting, and it changes tone to, goes form faster louder buzz to slower every once an while, seems to do it more wen its under 1/4 tank, is my pump going out??
Old Jan 24, 2013 | 05:26 PM
merc225hp's Avatar
merc225hp
After going through over four pumps in the last few year I will say why yes it is. Change it before it leaves you stranded.
Old Jan 24, 2013 | 05:39 PM
guzman's Avatar
guzman
Default Pumps
What brands did you use that caused that much trouble? I bet your damn good at changing a pump by now.
Old Jan 24, 2013 | 05:55 PM
gdstock's Avatar
gdstock
Denso. Avoid Airtex like the cl@p!
Old Feb 10, 2013 | 03:45 PM
KxRideRon125
instead of replacing the whole entire unit i can get a good deal from a buddy that has the pump itself but its for a built engine, it has alot more psi then stock, 145 to be exact, will this hurt anything??
Old Feb 10, 2013 | 03:54 PM
gdstock's Avatar
gdstock
Nothing other than possibly blowing out regulator, fuel leaks, etc.
Get the Denso and solve problem forever (or nearly). I have over 280,000 miles on a Denso fuel pump. Stick with something designed for the application.
I was in a bind about a year and a half ago and had to install an Airtex in step son's car (out of town trip to do it, and no time to order Denso) and had to replace it again last weekend.
Old Feb 10, 2013 | 03:55 PM
KxRideRon125
o yah ill just go with that thanks
Old Feb 10, 2013 | 04:06 PM
gdstock's Avatar
gdstock
I think the Denso for the Taurus was about $12 more than Airtex. But gas to drive 150 miles each way, towing a trailer, to work on it in an RV park......the $12 was a good investment. That one should last until the rest of the car falls apart!
Old Feb 10, 2013 | 04:20 PM
h3lzsn1p3r's Avatar
h3lzsn1p3r
witch should be soon because of that god awfull symbol on the front of it
Old Feb 10, 2013 | 08:30 PM
97ramrod1500's Avatar
97ramrod1500
4 pumps in 3 years! Wow that's ridiculous!
