37's and 8 inch lift. need help
Old Jan 25, 2013 | 03:09 AM
loveitlifted's Avatar
loveitlifted
Default 37's and 8 inch lift. need help
I]m knew to the world of dodges. I;m 16 and don't have much experience. I'm looking to put 37's on my truck with either a 7 or 8 inch lift. A 5 inch RC suspension lift and either a 2 or 3 inch body lift. Its pretty much all stock other than exhaust, headers and a ram air. Axles and gearing are both stock. Its got the 5.9. I tend to drive mostly on paved roads but when it rains I like going Muddin. I do drive in snow occasionally. What i looking for help with is do i need bigger axles if so what? What gearing would i need? I don't do much heavy hauling but i don't want to lose too much acceleration. Also do any of you guys had a rough country lift? how'd you like it, are the shock upgrades worth it? What kind of tires or what brand would you guys recommend? Thanks id appreciate all the help i can get.
Old Jan 25, 2013 | 05:19 AM
97tn4x4's Avatar
97tn4x4
7" and 37's look great. Um the axle thing is never agreed on but me personally if you spend most of your time on the road with a little mud here and there the stock axles will be fine. You'll want 4.88's to turn those 37's. For tires just find something that fits what you need.
Old Jan 25, 2013 | 08:15 AM
Check here for all your answers:
https://dodgeforum.com/forum/2nd-gen...d-how-tos-143/
Old Jan 25, 2013 | 09:13 AM
Wh1t3NuKle's Avatar
Wh1t3NuKle
+1 to 97tx4x4 suggestion!!
Rough Country offers 5" kit @ $800.
http://www.roughcountry.com/dodge_4wd_94-01.html
Originally Posted by jkeaton
Agreed with this, but fixed slightly.
Old Jan 25, 2013 | 10:35 AM
dlyter09's Avatar
dlyter09
Dude is 16. He will be abusing this thing on and off road.. your stock axles won't handle anything more than grandpa driving on the street.. hopefully you got a good bit of money to pay for all of this stuff.
Old Jan 25, 2013 | 10:37 AM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
^Agreed.
You will snap your axles like twigs, grenade your transmission and make your engine overly tired.
Do it right, my friend.
Old Jan 25, 2013 | 11:00 AM
dodgetrucker75's Avatar
dodgetrucker75
I'm running about 7" of lift and 37x13.50's I think its about a perfect look, but I would recomend swaping out to 3/4 ton or SRW 1 ton axles, they can be found 4;11's witch should work ok with out extra work, but 4;88's be good too, I'm running 3;73's and its fine, but they are being pushed by a 600+ HP cummins, and if you go that high, better go with a long arm, otherwise it will ride rougher than hell,
Old Jan 25, 2013 | 12:27 PM
merc225hp's Avatar
merc225hp
Couple of things here. First is I have a 7" lift with short arm's and my truck rides just fine. Next would be 4.11- 4.56 will work just fine with 37's as well for a PP, 1500 diff's will also be fine for a PP. So where are you in BC pm me if you want to keep it under wrap, I am in Sicamous BC if you are close we can hook up and yap about this stuff. I have some spare 5" stuff just sitting here and some wheels, later on in May I will have all my 7" stuff up for sale as well.
Keep your eye's open on kijiji for 2500's for sale, it's cheaper to buy a whole truck than just the diff's these day's. Just a example of what I mean below and then you will have all the parts needed for the swap.
Edit: Not all 16 year old's beat the sh*t out of there trucks guys.
2500 truck listing for Cheap http://bc.kijiji.ca/c-cars-vehicles-...AdIdZ445700580
Old Jan 25, 2013 | 12:51 PM
stewie01's Avatar
stewie01
Going taller?
Old Jan 25, 2013 | 12:52 PM
merc225hp's Avatar
merc225hp
^^^ Yes Sir I am, coil-over's here I come.
