intake manifold torque sequence
Old Jan 27, 2013 | 12:10 PM
QuadCabLuv's Avatar
QuadCabLuv
Default intake manifold torque sequence
Im in a bit of a pickle. I am halfway through the intake swap and realized I left my laptop at home which has the fsm on it. I need ti know the torque sequence and ft lbs for the manifold bolts.
Old Jan 27, 2013 | 12:13 PM
stewie01's Avatar
stewie01
http://www.dodgeram.info/tsb/2000/09-05-00.htm
Might help ya.
Edit:
this one is easier to read:
http://wiki.answers.com/Q/What_are_t...Dodge_Ram_1500
Old Jan 27, 2013 | 12:18 PM
merc225hp's Avatar
merc225hp
See if this helps you out.
Old Jan 27, 2013 | 01:06 PM
QuadCabLuv's Avatar
QuadCabLuv
You da man merc
Old Jan 27, 2013 | 01:26 PM
merc225hp's Avatar
merc225hp
Glad it helped you out, hope the job goes smooth for you.
Old Jan 27, 2013 | 06:55 PM
QuadCabLuv's Avatar
QuadCabLuv
Well it did until it came time to install the thermostat housing, fought with a leak for 4 hrs.
Old Jan 27, 2013 | 07:55 PM
crazzywolfie's Avatar
crazzywolfie
i got a bit of a question for you. how did you get the egr tube out of the back of the intake while it was on the truck? there is no room back there. i know i picked up a intake off a 94 and had to partially cut the tube and then lots of bending just to get it to break free. i think i smash the oil pressure sensor while i was at it.
Old Jan 27, 2013 | 08:37 PM
Wombat Ranger's Avatar
Wombat Ranger
Wolfie: Fully disconnect the nut that secures the EGR tube, unbolt the intake manifold, and slide it slightly forward before you lift it up and out. Then when you re-install it be very careful to make sure the rear gasket stays in place before you bolt the intake down.
Old Jan 27, 2013 | 08:58 PM
crazzywolfie
i was just wondering how you get the nut off. i don't think i could have got a wrench back there if is tried. i know when i got to do it on my 93 i should not have that problem but if i need to replace that tube on my truck it might be nice to know how to get one off in 1 piece instead of 2.
Old Jan 27, 2013 | 09:04 PM
Wombat Ranger
Oh that. I had to snake my hand up there with the 17mm (I think) open end from underneath the truck. And seriously, if you can, just delete the EGR. Such a stupid idea...
