Lift and gears
Old 01-27-2013 | 06:22 PM
southernpride_13's Avatar
southernpride_13
Default Lift and gears
have a 2001 1500 Ram 4x4 5.2 and I want to lift the truck and roll 37's. so my question is if I go ahead and swap my gears to 456's now before I do the lift how much is that gonna affect my truck. Right now I don't have the money to buy gears and a lift all at once nor do I have the time to install both at the same time so I want to do it in steps. Would I be better off doing the lift and tires first or the gears?
Old 01-27-2013 | 06:28 PM
h3lzsn1p3r's Avatar
h3lzsn1p3r
do the gears first it will make the rpms a little hight and you will lose atmost 1mpg its beter than doing the lift and tires then losing the trans before gears
Old 01-27-2013 | 06:33 PM
southernpride_13
Yeah I was thinking that too about how much stain the tires would put on the gears and tranny
Old 01-27-2013 | 06:35 PM
southernpride_13
Is there anything I should do to the tranny as well to beef it up a lil? I know the gears will take the strain off but is there anything else
Old 01-27-2013 | 06:36 PM
h3lzsn1p3r's Avatar
h3lzsn1p3r
35s are the max i would put on stock gearing and i push the limits because i am very cheap
Old 01-27-2013 | 06:40 PM
southernpride_13
Lol yeah the only problem with that is I'd have to get 35s then after gears buy 37s. I have 33s right now. I have a 2" puck spacer and blocks on right now and would like to add RC's 5" kit.
Old 01-27-2013 | 06:43 PM
h3lzsn1p3r's Avatar
h3lzsn1p3r
in th diy section there is a check valve delete for trans cooler
aside from getting a mega viper trans or going standerd there is no other worth while upgrades
Old 01-27-2013 | 06:44 PM
h3lzsn1p3r's Avatar
h3lzsn1p3r
why just go 33s with 4.56 till the 37s no need to get 35s im saying the max i would go on stock gears is 35s
Old 01-27-2013 | 06:45 PM
southernpride_13
Ok thanks
southernpride_13
Have u ever put gears in yourself?
Quick Reply: Lift and gears
