4wd help
Old Jan 27, 2013 | 09:24 PM
vaninator's Avatar
vaninator
Default 4wd help
hey guys i have a 2000 ram 1500 4wd 5.9 i was out taking the dog for a run here a hour or so ago and got to a spot where with the clay mud i got stuck temporarily and put it in 4 hi. moved a little bit but couldnt go anywhere in forward. so i put it in 4 lo and was able to get going again. i got past the rough spot and about 30 yards later it kicked out of 4 lo. so i put it in neutral and went back to 4 hi. just to be on the safe side. went anther 300 yards and it kicked out of 4 hi. what could be causing this? is there some sort of sensor that kicks it out if its not slick? its got me worried and confused. please help me figure this out asap so i can get it fixed... that is if i need to... thanks in advance
Posted from Dodgeforum.com App for Android
Old Jan 27, 2013 | 09:33 PM
My360's Avatar
My360
Never heard of that happening before. No, it should not just kick out of gear. Are you sure you had it all the way in gear? Also, make sure when in 4 low, don't go over 40km/h (not sure the speed in mph... 15?)
Old Jan 27, 2013 | 09:44 PM
Check the adjustment on the t-case shift linkage, and make sure nothing is worn.
Old Jan 29, 2013 | 08:47 PM
vaninator's Avatar
vaninator
where is the t case shift linkage?
Old Jan 30, 2013 | 09:33 AM
Gotta crawl under the truck. Start where the shift lever comes thru the floor, follow the linkage back to the t-case. make sure things are tight, and adjusted properly.
Old Jan 30, 2013 | 10:33 AM
h3lzsn1p3r's Avatar
h3lzsn1p3r
look the trans mount aswell you could be having exess movement of the trans and t case causing the shifter to hit where it goes through the cab floor and hitting it out of gear
Old Jan 30, 2013 | 11:00 AM
petea216's Avatar
petea216
Is the transfer case actually coming out of gear or is the front axle disengaging?
