Overhauling steering
Old Jan 30, 2013 | 03:47 PM
Ham Bone's Avatar
Ham Bone
Yeah i get that a lot. Haha I do want a Cummins one day but that day is not very near haha.
Still looking for confirmation that the 8.5 swap will fit on a 1500, if anyone knows or has any kind of idea.
Old Jan 30, 2013 | 11:10 PM
gdstock's Avatar
gdstock
It should work, but the correct question should probably be, "how much facrication would be required?"
So.....go for it and start a DIY thread!
Old Jan 30, 2013 | 11:29 PM
Wombat Ranger's Avatar
Wombat Ranger
Just want to point out that T-link and crossover steering are two different things.
Old Jan 31, 2013 | 09:53 AM
Ham Bone's Avatar
Ham Bone
I cant really fab stuff though.
I wish i could weld...
Old Jan 31, 2013 | 10:02 AM
petea216's Avatar
petea216
If you don't have means of fabrication, stick with the 1500 setup, but upgrade as HeyYou had mentioned (The stabilizing bracket kit DOES help and is a bolt-on kit) but if buying parts-store parts,I'd recommend Moog, and keep your receipts. Moog products use impact grade steel and are built heavier than factory. They also carry a lifetime warranty.
Old Jan 31, 2013 | 11:01 AM
Aubrey's Avatar
Aubrey
I put on the 1-ton hard components from same model year, AGR pump, Red Head box, and Borgeson intermediate shaft. It all bolts in fine. The 1-ton does change the design of the links.
Old Jan 31, 2013 | 11:07 AM
Ham Bone's Avatar
Ham Bone
You used the crossover from the new 08+ trucks?
Or a second gens 1-ton? That requires a lot of fab for a 2001
Old Feb 4, 2013 | 08:38 PM
Ham Bone's Avatar
Ham Bone
Since no one really knows if the crossover will fit a 1500 I guess Ill go with just replacing parts with better quality parts, like Moog. Apparently its the best option, but geez its a little pricey. But I guess steering isn't really the place to skimp out on uh?
I guess ill need all four of these tie rods?
https://www.oreillyauto.com/site/c/d...500&vi=1502303
And the track bar
And the dodge offroad brace, I never thought that the frame would flex on the shaft but thinking about it does. This one doesnt do that though, guess thats why its commonly recommended?
http://www.dodgeoffroad.com/store_DORbrace2g.php
All of that is about 800 bucks. whoa!!!
Is Moog stuff really worth the price? Ive never had experience with steering components so i just don't know.
Also I assume I need all the new bushings and stuff but that confuses me too.
Would I likely need a pitman arm?
And can I have some advice on what to look for when I check my current steering components before I go replacing everything ***** nilly?
Old Feb 5, 2013 | 01:35 AM
Wombat Ranger
If you really like your truck and want to keep it a long time get Thurenfab's crossover setup for 2nd gens and a Dodge Off Road track bar. I doubt you will be complaining then. Top it off with a redhead or borgeson box and DOR's steering shaft stabilizer and you'll be set.
Old Feb 5, 2013 | 08:01 AM
Milan's Avatar
Milan
i replaced my steering stuff with 1 ton stuff a couple years ago. i used 98-99 1 ton stuff. it worked on my 99 1500 and swapped right over when i did the d60 swap. i never looked into the new 09+ stuff. when i bought my 98-99 1 ton steering parts it cost me $180 shipped. and i replaced my track bar with the XRF adjustable bar for $120 shipped. the xrf bar is alot beefier than the stock bar.
stock track bar vs XRF track bar
