need help
Old Jan 31, 2013 | 05:42 PM
86yotacole's Avatar
86yotacole
Default need help
ok i bought a 96 ram from a relative, it ran fine for months and then decided all of a sudden to cut off and not crank back up. it is a 318 w auto tranny reprogramed ecu sct scanner programer. and here is what it is doing, every relay under the hood will click on and off repeatedly, turning the fuel pump on and off as well as the ac compressor on and off. it will crank on starting fluid. and the check engine and gen light willo come on and off as the relays click. i have checked ignition switch, all relays, all fuses, crank position sensor, ignition coil, altanator, batery leads, fuel pump, distributor basicaly everything but nothing is bad. i am compleatly stumped on this has any one had this happen to their ram or have an idea what it might be causing this
Old Jan 31, 2013 | 10:41 PM
How's the battery?
