95 ram 1500 loud squiling noise when turning or bounceing.
Old Feb 2, 2013 | 11:51 PM
Dodgeman512's Avatar
Dodgeman512
Default 95 ram 1500 loud squiling noise when turning or bounceing.
Im kinda new to this forum. I have a 95 Ram 1500 5.2 V8 magnum. about 6-7 months ago a was runnin thru some mud pits an my suspension started sqeekin its only goten worse over the months. im not sure if its ball joints or what. tire wear is even so im kinda lost. any ideas??!?!?
Posted from Dodgeforum.com App for Android
Old Feb 3, 2013 | 11:14 AM
Got grease fittings on your various joints? Lube them fellers up, and see if it helps.
Also might spray some variety of lubricant on the various control arm/shock bushings.
Old Feb 4, 2013 | 06:33 AM
Dodgeman512
there isnt any grease fittings. what would you suggest for a good lube spray?WD-40 just doesnt seam to do it. i went ape **** on the front end with a can an didnt help
Old Feb 4, 2013 | 08:26 AM
Brian_'s Avatar
Brian_
mud causes the bushings to dry out, especially when the truck isn't washed in a reasonable amount of time. lube every busing you see, then you'll be set.
Old Feb 4, 2013 | 08:56 AM
Spray white lithium grease. Good Stuff.
Old Feb 4, 2013 | 11:18 AM
Aubrey's Avatar
Aubrey
Lithium grease is good and I'd do one component at a time so you can narrow down where it is coming from.
Old Feb 5, 2013 | 10:05 AM
Dodgeman512
awesome. thanks for the help guys.
