98 Ram 1500 won't start, has spark.
Old Feb 3, 2013 | 06:16 PM
dlyter09's Avatar
dlyter09
Ok that makes sense.. Never had much information about that.. So it is either pump or wiring..
Old Feb 3, 2013 | 08:43 PM
gdstock's Avatar
gdstock
Isn't there a relay for fuel pump? Check fuse, and swap the relay with another and see if that works. Easy check.
Old Feb 5, 2013 | 03:14 AM
A-teamster's Avatar
A-teamster
Well, it was indeed the fuel pump! I got a new carter from motion auto for $202 and slapped her in there and she fired right up. While I had the lift I put in a new tranny filter too. Between those two things I can't believe the difference it's made in lowend and just sheer response! I bought the truck about 6 months ago and it's like a whole new truck now. Is there anything you guys would recommend doing or checking after driving on a weak fuel pump for who knows how long?
Old Feb 5, 2013 | 08:27 AM
Just make sure there aren't any fuel leaks. Aside from that, should be golden.
Old Feb 12, 2013 | 09:33 PM
Jonathan111's Avatar
Jonathan111
New Member
Default 98 2500 with 5.9 wont start has gas and spark seems weak
I got a 98 2500 reg cab with a custom flatbed it has the 5.9l gas and I was driving it everyday parked it came back an hour later it wouldn't start never did it before I assumed crank sensor so put a new 1 on checked spark it has spark but seems weak I got another 01 2500 ext cab same motor checked spark on it it seems like its blue and sparking fast this 1 is orange and slow my buddy said the ground from motor to firewal was smoking could a bad ground cause the weak spark and stop truck from running
Old Feb 12, 2013 | 09:39 PM
Weak spark will keep it from firing. Are the plugs wet??
Fix the ground, see if that gives you better spark.
From a previous thread, I learned that a marginal crank sensor can ALSO give you a weak spark, and not always consistently. (consistently on individual cylinders, but, its not an all-or-nothing affair) Might wanna look at the coil as well.
Old Feb 12, 2013 | 09:43 PM
gdstock's Avatar
gdstock
Yes.....but if you know this is smoking, wouldn't it be a natural instinct to fix that......before the truck catches on fire?
