Another Misfire/Loss of Power Thread
Old Feb 4, 2013 | 12:32 AM
QuadCabLuv's Avatar
QuadCabLuv
In that case i will be curiously waiting for your fix.
Old Feb 4, 2013 | 12:56 PM
adwood19's Avatar
adwood19
New plugs are in and ran it without the front O2 sensor to rule out the cat. Only change was a P0171, but I'm assuming that's because of the O2 sensor.
thoughts?
Posted from Dodgeforum.com App for Android
Old Feb 4, 2013 | 01:34 PM
Timothy Watrous's Avatar
Timothy Watrous
whats your fuel pressure?
and whens the last time you cleaned your tb
Old Feb 4, 2013 | 02:20 PM
adwood19's Avatar
adwood19
That's one thing I haven't been able to check yet. I'm one of the lucky ones without a schrader valve on the fuel rail, so I'm not really sure how to do it.
Old Feb 4, 2013 | 02:51 PM
gdstock's Avatar
gdstock
I would think that one could install a shcrader valve in the fuel line....or would like to think that.
Old Feb 4, 2013 | 02:54 PM
stewie01's Avatar
stewie01
I think it's plastic rails on the year(s) that don't have the schrader valve.
Old Feb 4, 2013 | 06:02 PM
adwood19's Avatar
adwood19
Well I didn't have any luck finding a fuel pressure kit that came with it's own T & valve (that would work with the metal line) but I did pop the fuel line out without bleeding it first, and there was definitely quite a bit of pressure in there! I've got no clue of exactly how much though...
On a brighter note, I took Timothy's idea and checked the throttle body as well. It had only been 8-10,000 miles or so since I cleaned it so it wasn't too bad. I did go ahead and pop it off and gave it a quick cleaning and the truck definitely runs a lot better than it was. Better throttle response, better power up hills, I even think it sounded better.
I'm not totally convinced that the truck is back to normal though. I don't know if it's just me or not but it still feels like it's missing a little power somewhere. It's on the market now though... so hopefully someone will take a chance on it!
