46RE Transmission Slip at 2k?
Old Mar 9, 2013 | 07:08 PM
  #71
gdstock's Avatar
gdstock
Double check the TV cable,,,,,,,and set it correctly!
Old Mar 9, 2013 | 07:12 PM
  #72
zman17's Avatar
zman17
Retired Moderator - RIP
Originally Posted by gdstock
Double check the RV cable,,,,,,,and set it correctly!
Can you tell me where the RV cable is? And I'll adjust it pronto.
Old Mar 9, 2013 | 07:21 PM
  #73
gdstock's Avatar
gdstock
mmm......I have NO idea what you mean (and I'm sticking to it.....).
Old Mar 9, 2013 | 07:33 PM
  #74
zman17's Avatar
zman17
LOL, no editing allowed.
Old Mar 16, 2013 | 09:56 AM
  #75
stewie01's Avatar
stewie01
So just a little update, still have a slight *whateveritis* around 2k, it is less noticeable with the BW Solenoid though.
And maybe the most important observation, it WON'T shift funny when it's cold. It shifts perfectly until everything gets all warmed up, than I have that issue...
Old Mar 21, 2013 | 06:14 PM
  #76
Augiedoggy's Avatar
Augiedoggy
Originally Posted by stewie01
Guess I shouldn't see how fast I can go in 2nd either, just over 70mph BTW
+/- 25,000 miles on a rebuilt 46RE, not too bad....
well that might explain why you only got 25,000 out of it
Old Mar 21, 2013 | 06:37 PM
  #77
stewie01's Avatar
stewie01
Gotta see what it's capable of!
Actually I have an update too, said before it didn't shift weird until fully warm, which is true, BUT even at fully warm if I start off in 2nd, it doesn't shift funny at all.
There was slight oddness before in 2nd with the stock Governor Solenoid, non with the BW Unit in 2nd.....
Old Mar 21, 2013 | 06:41 PM
  #78
Augiedoggy's Avatar
Augiedoggy
hows the fluid condition? the new soleniod bought me about 8,000 miles before the tranny failed me anyway so it may be helping flow but other things can still be plugged. You did change the filter right?
Old Mar 21, 2013 | 06:52 PM
  #79
stewie01's Avatar
stewie01
Fluid was clean, there are pics of the magnet and fluid a page back, no I didn't change the filter, I did a fluid and filter swap when we moved back to Georgia, roughly 4 months prior to this work.
Fluid looked good, so I reused the filter...
Stock Governor Solenoid and assembly were clean and unclogged too.
Old May 25, 2013 | 02:23 PM
  #80
stewie01's Avatar
stewie01
So here's an update. New solenoid and pressure sensor didn't fix the problem.
It hasn't gotten any worse, but hasn't gotten any better either. It's the same...
Adjusted the TV cable today, went out for later & firmer shifts. Finally got to test drive it, the glitch is MUCH less noticeable, it almost isn't.
OD shift kicks in at 60MPH, truck has much more power under the pedal, and the shifts are SMOOTH, I mean I can barely feel them.
So far I'm happy
