Power lock help
Old Feb 6, 2013 | 05:54 AM
piemxzhome's Avatar
piemxzhome
Default Power lock help
I have a 1997 dodge ram 1500 sport 5.9L that every time you hit the power lock switch it will lock or unlock and the blow the fuse I've tried to put a bigger fuse in and it blows all of them. Can any one help?
Old Feb 6, 2013 | 06:31 AM
kejobe's Avatar
kejobe
Sounds like theres a short. Start tracing the wires.
Old Feb 6, 2013 | 07:59 AM
^^That. Something is shorted. Start tracing the wiring and find it.
Old Feb 6, 2013 | 08:49 AM
petea216's Avatar
petea216
Common places wires get chaffed are where the penetrate the doors, body. Anywhere they go through something. If wiring isn't the culprit, it'll be a bad switch or lock actuator/solenoid.
Old Feb 6, 2013 | 09:20 AM
In the tubes between the body and doors is a favorite spot as well.
Old Feb 6, 2013 | 09:28 PM
dhvaughan's Avatar
dhvaughan
i had to trace the PDL wiring in the wifey's explorer. it had a broken wire in the door hinge duct - between the door and under dash. the fords also have splices in the harness that lays in the doorway kick plates which tend to corrode.
