So I installed the rock solid ram steering parts on my 01 dodge ram automatic, went in pretty good no hiccups, was tight sliding the bushing onto the steering shaft but it went on, not all the way to the lip but real close, anyways i took it for a test drive, its a little too tight and the gear shifter slightly moves with the steering wheel, do i need to take it off and sand it down or do you guys think it will break in with driving a while, thanks for any info
