rear axle swap
Old Feb 11, 2013 | 06:18 PM
dodge_ power_rules's Avatar
dodge_ power_rules
Default rear axle swap
I've got a 2000 ram 1500 that needs a new rear axle. Was wondering if its possible to swap the rear axle from a 2002 ram 1500 into it. Any info would be very much appreciated
Old Feb 11, 2013 | 07:48 PM
Wh1t3NuKle's Avatar
Wh1t3NuKle
If the rear is a Chrysler 9.25", then yes it will swap.
https://dodgeforum.com/forum/2nd-gen...ram-axles.html
Welcome to DF. Do some searching about and you'll find some slight differences to be aware of, like the VSS (speed sensor) over the years. 2000-02 should be the same, but don't quote me on that.
Old Feb 11, 2013 | 07:57 PM
dhvaughan's Avatar
dhvaughan
careful. 94-01 1500 is 2nd gen with chrysler 9.25 rear. 2002 is 3rd gen with i don't know what.
Old Feb 11, 2013 | 08:05 PM
Wh1t3NuKle's Avatar
Wh1t3NuKle
Right, but didn't some 02 have 2nd gen parts like the magnum drivetrain (magnum, 46re, etc.)? Or was 01 the partial change?
Old Feb 11, 2013 | 08:06 PM
stewie01's Avatar
stewie01
From what I've found it is the 9.25 rear.
http://www.mopar.com/dodge/ram-1500/...0254/129/3509/
Even the Quad Cab 4wd lists the 9.25
Old Feb 11, 2013 | 08:10 PM
dhvaughan's Avatar
dhvaughan
2002 2500/3500 was still a 2nd gen with 360 engine, 46re, d60, etc.
but i don't know anything about the 2002 1500.
Old Feb 11, 2013 | 08:11 PM
stewie01's Avatar
stewie01
Where's drewactual when you need him?
I didn't think the Hemi was around till the '03 model, so the '02 got the 5.9L 360, at least for V8's...
Old Feb 11, 2013 | 09:09 PM
Ham Bone's Avatar
Ham Bone
I think they actually discontinued the 360s but kept the 318s for a while but im not sure. I know of a lot of early third gens with 318s but no 360s
I also think the 9.25(or some variant of it) was used up until rather recently. But i really dont know for sure either
Old Feb 11, 2013 | 09:13 PM
V10Rampower's Avatar
V10Rampower
there were 5.9L 360's and 8.0L V10's put in the early 3rd gens so id assume that the drivetrain's were similar to the 2nd gens until the hemi rolled around
Old Feb 11, 2013 | 09:20 PM
dodge_ power_rules
Well I hope they are the same. The limited slip in the 2000 is shot and I have no knowledge in replaceing it and the rear axle from the 2002 is easy to get if it bolts in
