Front end rattle!!??
Old Feb 12, 2013 | 06:51 AM
keith97's Avatar
keith97
Default Front end rattle!!??
I have a 1997 Dodge ram 1500 4x4.. I have this terrible rattle thumping sound coming from the front end. It sounds.like rhe front axle is going to fall out from under the truck.. I have already replaced the frac bar, put on new shocks, and this past weekend I unfortunately had to put on new hub bearings.. I am at a loss to what might be causing this thumping sound... If anyone has any ideas PLEASE let me hear them..
Old Feb 12, 2013 | 07:05 AM
dhvaughan's Avatar
dhvaughan
hub bearings
track bar
ball joints
tie rod ends
front axle u-joints
lower shock bolts (torque to about 110#).
when does it do it?
is it a rotational noise like an axle or bearing
or is it a noise going over bumps?
Old Feb 12, 2013 | 04:11 PM
keith97's Avatar
keith97
Hub bearings are new.. shocks are only about a year old.. trac bar was just replaced last summer.... and the noise is only when going over bumps or a rough road..THANKS
Old Feb 12, 2013 | 05:22 PM
stewie01's Avatar
stewie01
Shocks may be a year old but are they torqued down to spec?
Old Feb 12, 2013 | 06:39 PM
dhvaughan's Avatar
dhvaughan
check shock lower bolts first. they'll rattle like crazy if only torqued to 50-60 pounds. the rattle is directly under driver and passenger feet.
next grab the tire at 12 oclock with both hands and push/pull with all your might. should be no movement. if the wheel wobbles or rattles investigate ball joints and possibly bearings but your new bearings pretty much rule them out.
to check upper lower ball joints, jack up the tire 2-3 inches off the ground. place a large pry bar, crow bar, or jack handle under the tire and pry up while watching upper and lower ball joint for movement. should be none.
since the rattle is only over bumps its probably not front axle u-joints but check them anyway. with tire on ground grab the inner half of ujoint/axle and rotate back and forth. should be no movement or play.
Old Feb 13, 2013 | 06:45 AM
keith97's Avatar
keith97
Torqued the lower shock bolts ladt night.. they were a little loose. Did some more looking around and noticed that noth swaybar links are shot and so are the swaybar bushings.. figured that could be a noise maker also.. what you guys think. Going to replace them this weekend.. see if it helps
Old Feb 13, 2013 | 07:10 AM
dhvaughan's Avatar
dhvaughan
swaybar link bushings can rattle.
swaybar bushings would have to be really bad to rattle, but if they're hard or cracked or falling apart you'll be better off with new.
Old Feb 14, 2013 | 09:18 PM
Michael Fralick's Avatar
Michael Fralick
Kudos man, I have noticed the same thing on my truck. I just barely replaced the swaybar links, they were pretty bad, lol. And in about a half hour I will go check my shocks because they're aftermarket! Thanks for the tip on this thread!
