change engine & trans
Old Feb 18, 2013 | 01:33 PM
gordie's Avatar
gordie
Default change engine & trans
Hey guys I have a 96 ram 1500 with 480kms but it still runs like a ram but was thinking on either puttng in replacement used 5.2 engine w/trans with 200-300 kms due to the fact this baby has no rust anywhere. But was also thinking would a 5.7L fit in this truck due to this is a lg truck full size 8ft box club cab and just thought maybe I would fine a 5.7 to put in this instead.
Old Feb 18, 2013 | 02:58 PM
Sooper's Avatar
Sooper
Quick question, do you mean the Magnum 5.9L 360, or the Hemi 5.7L from a later model?
The 360 swap would be fast and relatively easy. The later model Hemi would not only be much more difficult but it would be on a whole new level...no longer just a swap but a complete modification of almost every system that connects the drive train to the truck.
Old Feb 19, 2013 | 09:34 AM
gordie's Avatar
gordie
Default Sooper
Thanks sooper ya this truck for a 96 is in great shape and because I just fixed 98 dakota up to almost new state and drove it for 2 yrs and pulled out in front of a lady and yes I'm still pissed that I did that to my self but anyways this truck 96 ram has a 5.2 with 480kms but body has no rust so I was thinking on either getting another 5.2 with 200-3 kms with trans or the 5.7 not sure yet but thanks for info though. But anyways I can't seem too find this switch on the emergency pedal because my light come on 3-4 sec after start and I posted it on here and they said there is a switch on the top of pedal.
Old Feb 19, 2013 | 10:45 AM
Sooper's Avatar
Sooper
You said the Brake light is illuminating a few seconds after you start the vehicle?
I don't think it's the pedal switch. It would be on immediately, not after a few seconds.
I suspect air trapped in a line or low brake fluid level. If you haven't already checked your brake fluid level I would suggest that. Then, perform a few hard slam full lock brake stops and see if that dislodges any trapped air bubbles.
Old Feb 20, 2013 | 09:57 AM
gordie's Avatar
gordie
Default Sooper
Thanks dude I'll that those and thanks for engine tip with 480 but still runs good like a dodge but with the Canadian etest these days and the body in great shape I don't have a lot in her so I thought finding another motor an trans around 2-300kms would be good.
Thanks
Old Feb 20, 2013 | 10:22 AM
petea216's Avatar
petea216
Not to be rude, but try to use a little more punctuation. It makes a post easier to read and understand. Anyway, is the only reason for wanting to replace the engine because of the high kilometer-age (if that's a word). As Sooper said another 5.2 Magnum would be simple and easy to do. Swapping up to a 5.9 Magnum would be just as simple and easy except the computer would have to be changed (or maybe just flashed, not 100% on that one). The 5.7 is a Hemi not a Magnum and is 3rd and 4th generation motor, and isn't directly compatible with our 2nd gen trucks. Installing a 5.7 Hemi would require quite a bit of modifications.
Old Feb 20, 2013 | 10:23 AM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
Technically, the Hemi IS a Magnum, just not in the sense we think of.
You would be far better served in getting a decent 360, doing some internal work, getting the PCM reflashed, and dropping that in. More than enough power for daily work.
Old Feb 20, 2013 | 10:31 AM
petea216's Avatar
petea216
I knew I was gonna catch grief for that lol. I realize that but for sake of this post I labeled them as two different classifications of motor.
Old Feb 20, 2013 | 10:42 AM
dodge dude94
Yeah, just tossin' ya some crap.
Old Feb 20, 2013 | 11:57 AM
petea216's Avatar
petea216
