Dodge experts please
Old Feb 18, 2013 | 05:04 PM
BigBlackDodge961's Avatar
BigBlackDodge961
Default Dodge experts please
Hey everyone!
First i want to say thank you to everyone that posts useful info on DodgeForum.com! I have been reading the forum for years now and have just decided to join!
Well heres my Question:
I have a 97 Dodge ram 1500 5.9 4wd and i have done many mods (thanks to DodgeForum) All my mods are listed in my sig. I am getting about 12mpg on 93 octane gas.
I have searched the forum up and down and have found lots of answers to my question im going to ask but i would like to start a new thread to compile everything together.
I want to know the Best mods for Gas mileage.
What i have came up with is,
Ngk V power is a respected spark plug
Magnacor Sparkplug wires are great
Im not to sure on a Distributor cap or rotor button
As for ignition coil majority says to stick with the stock one
The 14x3 air cleaner is good but when i tried one my throttle linkage was in the way...
So everyone ive done my research but i would like to know everyones opinion on some things yall do for better MPG
Thanks in Advance!
Also my cylinder 8 burns a very minimal bit of oil but every once in a blue moon it will idle a little funny for a sec until i touch the gas pedal then it evens back out. So i think thats why i cant run a normal champion plug cause it misfires on cylinder 8 with them.
Old Feb 18, 2013 | 05:13 PM
nvrsftram's Avatar
nvrsftram
12 mpg is about as good as it gets, dont think there is really any mods worth a noticable difference in mpg, drive down hill, im no expert though
Old Feb 18, 2013 | 05:19 PM
BigBlackDodge961
Hahaha thanks for the reply! I baby it i try to keep it under 2k rpm and i try to go down hill as much as i can hah
Old Feb 18, 2013 | 05:42 PM
merc225hp's Avatar
merc225hp
Fix the plenum gasket that will solve the #8 issue, do a comp or leak down test to see if you have cracked heads. Jet chip is snake oil same with the TB spacer. 12-16mpg is average for these trucks. Re-gearing my or my not help mpg, chances are you have 3.55 add that with 33's for tires and it will lug the motor, 3.92 or 4.10 gears are better with your tire size. Look at getting a SCT tuner that might also help mpg. Does the truck still have a cat under it?
Old Feb 18, 2013 | 05:47 PM
BigBlackDodge961
If it was the plenum gasket wouldnt it misfire/ burn a little oil on more than just cylinder eight?
also what do you mean by the jet chip and tbs is snake oil? what would you recommend?
Thanks!
Old Feb 18, 2013 | 05:51 PM
BigBlackDodge961
Yea it does have a cat but its gutted and the rest of the exhaust is straight piped. I forgot to metion that if i put octane booster like brand 104 octane boost it really pisses my truck off and throws the cel for cylinder 8 misfire
Old Feb 18, 2013 | 05:56 PM
Matt Nickerson's Avatar
Matt Nickerson
Oiled up #8 plug is a symptom of blown plenum gasket. Verify by pulling the throttle body and looking for pooled oil in intake (given that you have PCV valve from the dealer). Jet chip and tbs give no benefit to performance or mpg, an SCT from hemifevertuning or superchips 3815 is better alternative. There's also no benefit to running octane booster or premium gas, given that your truck is running correctly.
Old Feb 18, 2013 | 06:02 PM
merc225hp's Avatar
merc225hp
Originally Posted by BigBlackDodge961
If it was the plenum gasket wouldn't it misfire/ burn a little oil on more than just cylinder eight?
That depends on how bad the plenum gasket is blown.
Thanks!
I recommend you remove them both. The pcm will over ride/write the jet chip, TB spacer only works on TBI engines not MPI engines, so it does nothing at all. Look at the SCT tuner that will put a smile on your face.
As posted do a comp test see what 8 has for comp, odd's are it's way down.
Old Feb 18, 2013 | 07:27 PM
crazzywolfie's Avatar
crazzywolfie
if the plenum gasket was leaking bad enough it could cause a miss. essentially a leaking plenum gasket is the same as a vacuum leak. you can usually check by hooking a vacuum/pressure gauge to your valve cover where the pcv valve is. normally you should see a bit of pressure but if your plenum is leaking bad enough to cause a miss you may see vacuum which is bad.
Old Feb 18, 2013 | 07:49 PM
BigBlackDodge961
Ive been looking at the SCT tuner...what should i get though? the website is kind of confusing...
I really appreciate all the replys!
