Most helpful aftermarket gauges
Old 02-20-2013, 11:32 AM
Nsmitty21's Avatar
Nsmitty21
Nsmitty21 is offline
Default Most helpful aftermarket gauges
I need to replace my tranny and with the new one I would like to get a tranny temp gauge to help keep tabs on it. I am looking to get a 3 gauge pod and wanted to know your thoughts on the most helpful gauges to have. I want the tranny temp gauge, a air psi gauge for airbags I plan to put in the rear. Other than that I am looking for another gauge to put in the last pod. I can find a 3 gauge pod for $30 less than the 2 gauge pod so I would like the other gauge. I am thinking about an air/fuel mixture gauge, maybe a fuel pressure gauge, exhaust temp gauge, or trans pressure gauge. What do you guys think would be the most useful to fill the last pod??
Old 02-20-2013, 11:49 AM
redneck_ram's Avatar
redneck_ram
redneck_ram is offline
oil psi gauge
Old 02-20-2013, 12:30 PM
merc225hp's Avatar
merc225hp
merc225hp is offline
+1 on the oil psi gauge
Old 02-20-2013, 12:35 PM
jkeaton is offline
Dodge Forum Administrator
Vacuum gauge...helps you obtain the best mileage ; )
Old 02-20-2013, 01:13 PM
Nsmitty21's Avatar
Nsmitty21
Oil pressure gauge. Is the one from the factory not good enough?
I did think about a vacuum gauge too.
Old 02-20-2013, 01:25 PM
merc225hp's Avatar
merc225hp
The factory oil psi gauge is iffy at best, so a mech oil psi gauge is the better choice.
Old 02-20-2013, 01:38 PM
Adobedude's Avatar
Adobedude
Adobedude is offline
Another vote for oil pressure
Old 02-20-2013, 01:44 PM
Nsmitty21's Avatar
Nsmitty21
I guess I didn't realize that the factory ones were that unreliable. Thanks for letting me know!
Old 02-21-2013, 12:35 PM
Kevin M Lopota's Avatar
Kevin M Lopota
Kevin M Lopota is offline
Vacuum for mileage
Old 02-21-2013, 01:02 PM
gdstock's Avatar
gdstock
gdstock is offline
I run vacuum, tranny temp, and a/f.
Quick Reply: Most helpful aftermarket gauges
