Transmission help
Old Feb 22, 2013 | 08:26 PM
FreddyUSMC's Avatar
FreddyUSMC
Default Transmission help
I have a 2001 Ram 1500 5.2L manual trans. My back up lights quit working and I read that it might be the back up light switch. I have checked the bulbs and wiring. Can anyone help me find out what transmission is in my truck so I can get a new switch? I checked the info plates on the door and under the hood and no dice.
Old Feb 22, 2013 | 08:39 PM
gdstock's Avatar
gdstock
Switch is in tailshaft of transmission. Check it first. Not common fairure. May need tightning or loosen slightly. check connector.
Parts manual and service manual located in FAQ/DIY section - free download.
Service Manual HERE.
Parts Manual HERE.
You can get a Build Sheet for your truck HERE.
Welcome to DF!
Old Feb 22, 2013 | 08:45 PM
crazzywolfie's Avatar
crazzywolfie
have you checked your fuses?
Old Feb 22, 2013 | 10:26 PM
FreddyUSMC's Avatar
FreddyUSMC
Yea I also checked the fuse. The only thing I can gather is that is the switch.
Old Feb 22, 2013 | 10:28 PM
FreddyUSMC's Avatar
FreddyUSMC
gdstock thanks. I will get after it tomorrow morning. I have all weekend to figure it out.
Old Feb 22, 2013 | 10:40 PM
crazzywolfie
you may want to test for power at the switch before you replace it. as long as the key is in the run position there should be power at the switch.
Old Feb 23, 2013 | 11:44 AM
FreddyUSMC's Avatar
FreddyUSMC
I will test the switch today. Thanks
