98 ram 2500 360 running problems
Old Feb 24, 2013 | 06:29 PM
Ktmracer101's Avatar
Ktmracer101
Default 98 ram 2500 360 running problems
my 5.9 360 will start up and idle fine but at steady throttle at anything 2k rpm+ the rpms will jump around anywhere from 50 to 150rpms and it it sounds like a sputtering kinda noise . ive replaced tps crank pos sensor cam posit. sensor cap rotor plugs n wires battery terminals used injector cleaner and dry gas please help
Old Feb 24, 2013 | 07:20 PM
Checked your plenum?
Test the TPS. Bad parts right out of the box aren't unknown...
Old Feb 24, 2013 | 07:31 PM
gdstock's Avatar
gdstock
Dry gas?????
Old Feb 24, 2013 | 08:38 PM
ReadRam's Avatar
ReadRam
Originally Posted by gdstock
Dry gas?????
Think he means Heet added to gas tank. Use the red. Look at that tps again, and sputter, clogged cat? Any cel's?
Old Feb 24, 2013 | 08:50 PM
gdstock's Avatar
gdstock
I'd check fuel pressure also!
Old Feb 26, 2013 | 12:57 PM
Ktmracer101
check engine is on but i havent scanned it yet i lent out my scanner at the moment but im thinking possibly the map sensor maybe?
