Ticking when trying to start
#41
I hate when I get logged out of the Internet and I lose the whole paragraph I typed. To sum it up trucks running good but will randomnly stall at idle. Usually won't idle rough it just stops. Doesn't happen Often maybe once a day. Getting code p1391 loss of camshaft crank. It is obviously happening after I did the tune up so I imagine its a result of something I did when doing the intake manifold or cap and rotor. I can list everything I've done. New cap rotor and camshaft position sensor. New plugs and wires. Plenum plate and intake gaskets. Cleaned iac and tested to verify motor still works. Tps is sending correct voltage with throttle plates opening. Plus the stall happens to little for me to suspect those.
#43
Not likely. If it shucked the gear or chain, it would be dead.
