Wheel bearings or?
Old Mar 1, 2013 | 06:20 PM
cutthroatxxx's Avatar
cutthroatxxx
Default Wheel bearings or?
When ball joints go bad will they make a knocking?@first I thought it was my u joints then maybe ball joints but I'm leaning towards wheel bearings..it started off squeaking then making a knocking sound.If I lift the wheel off of the ground&grab@12&6o'clock its tight but if I grab@3&7&rock it its loose what are do you think?
Old Mar 1, 2013 | 06:39 PM
guzman's Avatar
guzman
Default Lever
Jack the front end up and have a buddy take a bar and stick under the 6 o'clock position and try to rock the wheel while your underneath looking for the slack you say is present, might narrow it down some that way.
Old Mar 1, 2013 | 06:53 PM
newman1367's Avatar
newman1367
drag link or tie rod ends
Old Mar 1, 2013 | 07:59 PM
dhvaughan's Avatar
dhvaughan
check ujoints with wheels on ground, in 2wd, nice and level. reach behind the tire and grab the inner part of the axle and twist it back and forth against the outer half. should be zero movement and seal intact.
play at 3 and 9 sounds like tie rods, but do the pry bar test above for ball joints. look for where the movement occurs.
