3 and 6 misfire????
Old Mar 3, 2013 | 11:10 PM
Weld_It33's Avatar
Weld_It33
Default 3 and 6 misfire????
Hi there I am new to the Ram world. but here is the problem. I have had codes for 3 and 6 misfires. I have replaced the plugs, wires, coil, cap and rotor. I will clear the code but can still feel it in my pedal. then about a tank of gas later then it will pop those codes again. any ideas? thank you for your time.
Old Mar 4, 2013 | 12:24 AM
gdstock's Avatar
gdstock
Check routing of plug wires. There is a TSB in the FAQ/DIY section.
Old Mar 4, 2013 | 06:04 PM
Weld_It33's Avatar
Weld_It33
Thank you I'll have to check that out....if that doesn't work should I look at getting a new reluctor?
Old Mar 4, 2013 | 06:07 PM
merc225hp's Avatar
merc225hp
Compression or leak-down test the motor. Also read the plenum sticky thread.
