1998 Dodge Ram 1500 Transmission Issue
Old Mar 6, 2013 | 02:28 AM
darrenwilson247's Avatar
darrenwilson247
Default 1998 Dodge Ram 1500 Transmission Issue
Hello Team,
I have a 1998 1500 5.2 4wd with 184,000 miles. It just started violently "bucking" when it shifted into third at about 44-45 mph. If I slowed down and kept in 2nd manually, did okay but couldn't go more than 43 mph. I got a check engine light momentarily and then it extinguished. Haven't had a chance to check for the code.
I had trouble with it slipping when it was cold a few weeks ago and added Lucas transmission fix to the fluid. Did great for a couple of weeks and then this issue happened. I suspect it's the governor solenoid and governor pressure sensor from what I have read on the forum.
Am planning on dropping pan and replacing solenoids, filter and fluid. Do you think this will fix the issue or is it time to have a rebuild?
Thanks for your input.
Old Mar 6, 2013 | 06:17 AM
zman17's Avatar
zman17
Retired Moderator - RIP
Sounds like your cat is clogged. Read the plenum sticky on top of the page.
Old Mar 6, 2013 | 09:08 AM
Moved.
Old Mar 6, 2013 | 10:01 AM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
As zman said, you've got a clogged cat.
Likely a misfire too.
Read the plenum sticky and do a transmission flush as you put the Lucas in it. I've learned that if you get a slip when it's cold, the fluid is a bit low.
Old Mar 6, 2013 | 10:29 AM
gdstock's Avatar
gdstock
+1 more...and hope you did not screw up tranny pouring snake oil in it!
