lost all gears and reverse?
Old Mar 10, 2013 | 12:09 PM
christopher.l.manson's Avatar
Question lost all gears and reverse?
i bought a truck and it doesnt have any of its gears or reverse. i bought it pretty cheep knowing it have to be rebuilt or replaced but i was told that transmissions dont normally loose every gear and reverse. is this a sign of a bigger issue? and what would that issue be? dont want to rebuild it or replace it if its just going to kill all the gears again.
1998 dodge ram 1500 regular cab 4x4, 5.9l engine, 46RE transmission
Old Mar 10, 2013 | 12:26 PM
newman1367's Avatar
newman1367
It does happen, more than likely oil pump went south. But gear shift linkage may have issues, low fluid level or sticking manual valve in valve body. Even a broken driveshaft u-joint.
Does it have proper fluid level, gearshift undamaged? And driveline intact?
If 4wd maybe the problem is in the transfer case.
Old Mar 10, 2013 | 12:27 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Could be the transfer case. Also make sure TC is not in neutral.
Old Mar 10, 2013 | 12:33 PM
newman1367's Avatar
newman1367
You got me while I was editing!
Old Mar 10, 2013 | 12:56 PM
i checked the fluid and level was good so i dopped the pan and the fluid was really dirty with all kinds of particles in the bottom of it. as i was under it could notice the front seal was leaking pretty bad.
Old Mar 10, 2013 | 01:07 PM
newman1367's Avatar
newman1367
Have to rebuild the trans then or get a megaviper. http://www.transmissioncenter.net/dodge.htm
Old Mar 10, 2013 | 01:09 PM
thats what i figured. do you know of anywhere i can get the service manuals for a 98 ram and instruction on the trans rebuild?
Old Mar 10, 2013 | 01:21 PM
From the faq section here. Grab the 01 manual. It will be pretty much the same thing. There is also J415's trans thread, with links to a couple good walkthru's for rebuilding your trans.
Old Mar 10, 2013 | 01:39 PM
thanks i found a good rebuild one and the manual hopefully it wont take too long to rebuild it and get the truck back on the road.
Old Mar 10, 2013 | 03:06 PM
gdstock's Avatar
gdstock
Can be done in a weekend. Need a tranny jack and a press.
