Leveling the Rear ?
Old Mar 11, 2013 | 12:43 PM
Hylander7's Avatar
Hylander7
Default Leveling the Rear ?
99 1500 4X4, gasser
I raised my front 1.75" awhile back, but now my Rear is setting to low, About 1.5"
I want to raise it level or just a tad higher in the rear.
Was prefering an AAL but want a long leaf not the short ones, who makes them.
Seems most just offer the short leaf.
What about using an extra factory leaf from the junk yard, say the top or second leaf ?
Also will I have to get new U-bolts or canI use the ones I have ?
Old Mar 12, 2013 | 02:21 PM
chromed95's Avatar
chromed95
Add a leafs is probably your best bet. Not sure if you can take a leaf from one pack and add it to your leaf pack but maybe someone else will chime in on that. There's also the route of getting a bigger block under your leafs. You'll likely need new u bolts, depending how much thread you have left on your existing ones. Or, I also have a set of heavy duty aftermarket leaf springs that I pulled out of my truck and replaced with stock leafs that I could sell you. They added about 2 inches of lift in the rear
Old Mar 12, 2013 | 03:07 PM
Yinzer's Avatar
Yinzer
You could try to find a set of leafs and blocks from an offroad package like mine came with. Offroad package rams sit a bit higher than regular 1500's.
Old Mar 17, 2013 | 09:18 PM
Hylander7's Avatar
Hylander7
Can I use springs from a 2500 ?
Will they fit or are they wider ?
Old Mar 17, 2013 | 09:25 PM
dhvaughan's Avatar
dhvaughan
2500 is 3 inches wide. 1500 is 2.5 inches wide.
on my old chevy a long time ago, i got a set of springs from the junk yard along with longer u-bolts off some other vehicle. i took mine off and took the packs apart and added the 2 longest ones from the junkyard pack. i used a longer 5/16 bolt for the center pin, and cobbled up some kind of retainer.
it worked well, adding lift and a lot of stiffness.
Old Mar 17, 2013 | 09:55 PM
Hylander7's Avatar
Hylander7
Thanks
One more question.
Are the 1500 2 wheel drive and 4 wheel drive springs the same ?
I found a pair of 2 wheel drive springs local
Old Mar 18, 2013 | 12:12 AM
gdstock's Avatar
gdstock
Don't know, but checking the parts manaul download here will confirm if they are the same or not.
Old Mar 18, 2013 | 09:15 PM
dhvaughan's Avatar
dhvaughan
see here for the part numbers and specs used.
2wd and 4wd are listed as different.
http://www.generalspringkc.com/Leaf_...001_s/1912.htm
Old Mar 18, 2013 | 10:41 PM
Hylander7's Avatar
Hylander7
OK this is weird.
The 4X4 leaf packs are listed at 4/1 and 5/1
My leafs are 3/1 which are listed for 4x2 and only 1705 capacity.
I know my truck is stock and unaltered, so I wonder what gives
Chromed95:
How many is your leaf pack ?
Old Mar 19, 2013 | 07:10 AM
dhvaughan's Avatar
dhvaughan
there's a little bit of mis-print in the general spring chart.
if you scroll down you find 4wd 3/1 listed as part number 34-1337 for $189, but its not in the chart.
my 1500 also has the 3/1 pack.
4/1 and 5/1 very heavy duty. 5/1 is the "light duty" 2500 rating for the 9.25 axle.
watch closely on price. the 3/1 is $189 while the 4/1 is $109 and the 5/1 is $139
(plus shipping)
