Cab temp change
Old Mar 11, 2013 | 07:39 PM
KxRideRon125's Avatar
KxRideRon125
Default Cab temp change
i delted my ac system bc it hasnt worked in5 yrs anyways an i said hell with it an got a shorter belt, anyways the cold to hot temp ****, it doesnt work...any ideas...it didnt work before i deleted the ac either.
Old Mar 11, 2013 | 08:20 PM
Then it has nothing to do with deleting the AC. Check the linkages on the blend door and also make sure vacuum is going to the switch panel.
Old Mar 11, 2013 | 10:07 PM
gdstock's Avatar
gdstock
ifyoudeletedtheacidontsee whatdifference itwouoldmake whetereswitchworks or not,
Old Mar 11, 2013 | 10:35 PM
redneck_ram's Avatar
redneck_ram
gd, i think you have an issue with your spacebar. might want to get that fixed...
either that, or youve had a few too many tonight. time to put the adult beverages away for the evening. lol
Old Mar 11, 2013 | 11:07 PM
KxRideRon125
haha i thought only like switching form defrost to floor an mix requires vacum hoses? its plugged in the back of the switch to.
Old Mar 12, 2013 | 07:58 AM
Did you check the blend door or not?
Old Mar 12, 2013 | 08:27 AM
Scooter78's Avatar
Scooter78
I took my time and read this slowly thinking there would be a catch or a punch line at the end. Nope. Just a failed spacebar.
Old Mar 12, 2013 | 10:51 AM
gdstock's Avatar
gdstock
It was a sarcastic statement regarding punctuation in original post, which is difficult to read with lack of punctuation. Sometimes I cannot help myself.... (I'm sorry..)
Old Mar 12, 2013 | 12:54 PM
zman17's Avatar
zman17
Retired Moderator - RIP
If the "cold to hot" **** does nothing, you'll have to check the blend door motor and the lever between it and the blend door. You probably need one of these to fix it. http://www.heatertreater.net/index.html
