Help with adding Top Gun Customz Control arms
Old Mar 21, 2013 | 11:45 PM
merc225hp's Avatar
merc225hp
Originally Posted by SC01DodgeRam
And ill be up to 7.5 inches do you think i need a re clocking ring for t case and i just needed help with the bushing and stock bolts coming out. Saw where some people said they had to torch and grind cause they were like seized in there. I just want to be prepared for what im walking into. Any advice appreciated!
Gota sawz-all it will be your best friend for doing this job. That drop pitman-arm is only good for 3-6 inches of lift, get new lower control arm cam bolts before you start the work. A t case clocking ring is needed for any lift over 7", you will also be pushing the front DS length to it's limits flex it out (truck) and it will pull apart. The tranny cross-member is also subject to a mod as well if you 4wd this truck.
Old Mar 22, 2013 | 01:25 PM
SC01DodgeRam's Avatar
SC01DodgeRam
Alright thanks man just cut the bolt in the gap of control arm space on each side and then it would fall is it what im thinking. And ya i might have to wait on putting the coil spacers on then and just run it with the 5 inch coils and that drop pitman arm was said to be for 3.5 to 8.
Old Mar 22, 2013 | 01:41 PM
merc225hp's Avatar
merc225hp
Dude no really coil spacers on top of lift springs, not good or safe to do. You can buy Sj 7" coils in 1500-2500 gas flavor or 2500-3500 V10 or Diesel 7" (these springs in a half ton will net about 8.5 inchs of lift) springs for about $225 down there much better/safer way to go.
I am sure you are going of the web site for the info about that drop arm, can you give me a link to it please so I can check it out for you.
Your truck looks clean from the pix try all the bolts first, like now. See what they do, most times they are a pita at the frame end especially the top ones. The other pita ones will be the lower fronts (cam bolts) not cheap.
I thought I should add this warning as well.
Under NO circumstances are SKYJACKER® coil springs to be used in conjunction with any type of
coil spring or spring tower block/spacer. The use of coil spring block/spacers will allow ANY coil
spring to exceed its designed stress and travel loads allowing it be overstressed, oversprung,
fatigued, and possibly break. SKYJACKER® warranty is void under any such application.
Old Mar 22, 2013 | 01:45 PM
Wh1t3NuKle's Avatar
Wh1t3NuKle
Here is my contribution with regards to the control arm bolts.
https://dodgeforum.com/forum/2906660-post51.html
Now hurry up and get dirty with choice curse words.....
Old Mar 22, 2013 | 02:47 PM
SC01DodgeRam
http://www.topguncustomz.com/p-10631...itman-arm.aspx
Ill check that link out later im at work and i got 3.5 spacers on my stock 2500 coils now but if thats what happens with sj's than i wont so ill just stick with just coils for right now anyways just tryin to get everything good cause i got brand new mud grapplers i need to put on so not much more money for drive shafts and other stuff right now.
Old Mar 22, 2013 | 02:58 PM
merc225hp's Avatar
merc225hp
Interesting thanks. It looks just like the Sj 3-6 inch one, I will go out later and measure mine just to compare. I have 7" lift in mine so I kinda know what you can and can't get away with, if your not a big flexy type 4wd person you can get away without the clocking ring and just use the stock length drive-shaft, but you must be careful.
Old Mar 22, 2013 | 03:33 PM
SC01DodgeRam
Ya i called and made sure he said ya and on that thread you posted all you had to buy when done was new bolts the nuts and other cam piece was all good?
Old Mar 22, 2013 | 03:43 PM
SC01DodgeRam
Did you buy those bolts from dealerships or go with another bolt size
Old Mar 22, 2013 | 03:51 PM
merc225hp's Avatar
merc225hp
For control arm stuff yea that's about it. You will run into little things like the brake-line brackets that need to be modded or bent just odd's and end stuff. One tip I will add is unhook the front DS just make's thing's ez'er when changing springs when dropping the diff.
Old Mar 22, 2013 | 03:54 PM
merc225hp's Avatar
merc225hp
I bought my cam bolt's from the dealer, I have seen them posted on DF else where but I don't remember, try rock auto's web site. For the other one I had used one from another truck.
