Help with adding Top Gun Customz Control arms
Old Mar 22, 2013 | 04:51 PM
  #21
BIGRED97's Avatar
BIGRED97
http://www.dodgeoffroad.com/store_DORparts.php
this is the only other place other than the dealer i have seen the cam bolts. (scroll down and you will see them) don't have any personal experience with them but a few guys on here do and i think the guy makes this stuff is a member on here.
Old Mar 23, 2013 | 11:06 AM
  #22
SC01DodgeRam's Avatar
SC01DodgeRam
Alright thanks i appreciate yalls help ill post pictures soon with the new lift and tires. One more question since i got the 2500 diesel 5 inch lift coils to put on but i already have the 2500 either gas or diesel stock coils that come with the offrpad package on with 3.5 spacers. How much lift will those new coils give me? I think the other coils might be worn out to saw where they can start to sag an loose real height and those stock ones have bren on there since day 1.
Old Mar 23, 2013 | 12:13 PM
  #23
merc225hp's Avatar
merc225hp
Your 5" lift diesel coils should get you to 7" or just over. Link to info about stock coils and how much they lift http://dodgeram.org/tech/specs/springs.htm
Old Mar 26, 2013 | 11:38 AM
  #24
SC01DodgeRam
What size bolts would i need from that website the dealership it would be 133 dollars for all new control arm bolts but seeing what is a better price. Thanks
Old Mar 27, 2013 | 09:10 PM
  #25
Wh1t3NuKle's Avatar
Wh1t3NuKle
If you have a 2001 as stated in your profile, then you'll have 5/8" size for the lower control arms. The factory bolts are 16mm (lower) and 14mm (upper). You can search for this to confirm.
It looks like DOR is using the standard Grade 8 size bolts with a washer. They are not slotted like the factory cam bolts. I did mine in this fashion, which can be seen in the link I posted for you.
