CE Light and Codes
My CE light comes on and off, making me think there's a clogged sensor. Where on this site are the diagnostic codes? I stumbled across them once, but can't find them. Also, what is the key sequence with the ignition switch so I can get the light to blink the code?
Go here. it will tell you exactly what to do and what the code means.
http://dodgeram.org/tech/gas/Trouble/pcm_fault_code.htm
ORIGINAL: Tani1500
