Installing 2" leveling kit tomorrow, need some advice.
Old Mar 23, 2013 | 03:51 PM
Howells's Avatar
Howells
When I did mine. I removed the shock lower bolt and removed the 3 bolts that hold the shock tripod I call it and removed the shocks. You have to keep compressing the shock to remove it. Remove one link bolt on both sides so that you can remove the link or drop the sway bar completely 4bolts. Then jack up truck so that the axle is hanging high enough that when you push down on the axle it doesn't touch the ground. Make sure the wheels are off that way you won't have to jack it up as high. Then the spring should be easily. Removed. Install spacer then fight with the spring to get it back in. Then reinstall everything. Done
Old Mar 23, 2013 | 05:15 PM
gdstock's Avatar
gdstock
(you KNOW someone had to do this.......)
Old Mar 24, 2013 | 12:09 AM
Howells's Avatar
Howells
Agreed.
Old Mar 24, 2013 | 04:47 PM
nickr519's Avatar
nickr519
Hi all,
Thanks for all of your help! I ended up following the stock instructions pretty closely. Only difference being I compressed the coil springs in order to remove and reinsert them as I couldn't get enough clearance between the body and the front assembly, and was more than a little trigger shy to detach other suspension members. Here's some pics from the install:
http://imgur.com/a/H4ueg/all
I'll post pictures with the new wheel and tire getup once they're mounted tomorrow!
Old Mar 24, 2013 | 05:22 PM
gdstock's Avatar
gdstock
Originally Posted by nickr519
Hi all,
I like the "baby" jack on the driver side! ...lol.....
Old Mar 24, 2013 | 05:43 PM
nickr519's Avatar
nickr519
Yeah, the little guy! It was nice having both jacks to "walk" the front assembly up and down.
On another note, I just drove a little too fast and started to get what I can only imagine is what is known as the death wobble. No more driving this thing over 50 until I get an alignment done.
I've taken the truck to 85 before this and never had any problems, but HBS did say that sometimes the raising of the front can bring about the problem. Anyone care to guess what the odds are of it going away after the alignment?
Old Mar 24, 2013 | 05:50 PM
Jimythefan's Avatar
Jimythefan
Double check all the front end parts for wear first, then get it aligned and think about getting a better steering stabilizer. That will help.
Old Mar 24, 2013 | 06:03 PM
nickr519's Avatar
nickr519
will do, thanks. I am relatively certain my steering stabilizer is shot.
Old Mar 24, 2013 | 06:08 PM
Jimythefan's Avatar
Jimythefan
You won't need a double, a heavy duty single unit will work fine.
Old Mar 24, 2013 | 06:44 PM
kejobe's Avatar
kejobe
Lifting can bring out the death wobble. My assumption is that when lifted the caster is reduced which causes it.
I came to this theory by the fact that mine wonders on the road more after the level kit. But when I hook up the plow it doesnt do it as bad. I figure that the weight of the plow lowering the truck puts the caster closer to where it was before the level.
This is just my $.02 and I may be wrong.
