oil pan pick uptube
Old Mar 23, 2013 | 09:52 PM
dhvaughan's Avatar
dhvaughan
check for the inspection cover not being hooked into the oil pan lip correctly, and the flexplate hitting it.
i made that mistake. scared the **** out of me.
do you have a helper to start the engine, or turn the starter while you get under it?
if not, remove the spark plugs and turn the engine with a socket on the big crank bolt. 1-1/4 in.
Old Mar 23, 2013 | 09:54 PM
byronpen's Avatar
byronpen
yes i have oil pressure. I have to drop the pan again. FML
Old Mar 23, 2013 | 09:56 PM
dhvaughan's Avatar
dhvaughan
see my edit above.
what does FML mean?
Old Mar 23, 2013 | 10:14 PM
merc225hp's Avatar
merc225hp
+1 Check this first.
Old Mar 23, 2013 | 11:07 PM
Ham Bone's Avatar
Ham Bone
I bet it is the inspection plate. I had dinted mine in when I changed the pump. Rattled something fierce. I thought my truck was gonna explode
Old Mar 24, 2013 | 12:21 AM
Howells's Avatar
Howells
Also if everything checks out check your crank pulley the balancer might have broke off the back and it bouncing around the pully/shaft. It has happened on my truck. Would just be a coincidence since you just had the pan off but is another suggestion while your under there.
Old Mar 24, 2013 | 12:40 AM
CSDavies26's Avatar
CSDavies26
what does FML mean?
F*** my life....haha
Old Mar 24, 2013 | 10:03 AM
dhvaughan's Avatar
dhvaughan
we have a saying of exclamation around here - well, f*** me running
the response by someone standing neaby is - take off.
Old Mar 25, 2013 | 10:34 AM
byronpen's Avatar
byronpen
OK the pickup tube wasn't in its notch in the oil pan. was getting nicked.
Old Mar 25, 2013 | 01:04 PM
guzman's Avatar
guzman
Default Oil tube
Thanks for keeping us informed...
