Burning up fuse problem
Old Mar 24, 2013 | 10:02 PM
joshmopar's Avatar
joshmopar
Default Burning up fuse problem
So i just picked up this truck the other day and on the way home it blew the ign fuse, the one under the hood. As i was looking around the engine bay i saw that the smaller ground wire wasnt hooked to anything so i put it on one of the radiator support bolts. Not sure where it goes so any info on that would be nice if anybody knows. Anyways I replaced the ign fuse and truck fired right up. But went out tonight to start it and the fuse was blown. I went to put another one in and it popped as i was putting the fuse in. Anybody know where to look i would greatly appreciate it.
Old Mar 24, 2013 | 10:25 PM
gdstock's Avatar
gdstock
Hard to tell not knowing if anything has been added to the wiring.
From battery negative, a large cable goes to engine block. and smaller grounds to frame below battery, one to fender. I think there is a third, but cannot recall for sure.
Old Mar 24, 2013 | 10:56 PM
joshmopar's Avatar
joshmopar
Yea the kid before me added a bunch of off road lights and a cb radio. Well he kept the cb but neglected to tell me he didnt take the f******* positive wire out and just shoved it under the dash. Well as anybody with a brain knows its going to ground out if it touches the dash support. And that is exactly what was going on. The reason it didnt blow when i swapped the fuse the first time was because i had unhooked it oddly enough. But i hooked it back up after seeing if the blown fuse was the only problem. Now to just fix the other ugly wiring he did.
Old Mar 24, 2013 | 11:27 PM
gdstock's Avatar
gdstock
One thing I hate about buying any used vehicle - people that should not do wiring ALWAYS do, and they jack it up! That is why I conditioned previous post with "anything added..."
Check for other fubar issues. I am sure there is more! Good luck!
Old Mar 24, 2013 | 11:40 PM
joshmopar's Avatar
joshmopar
Yea, the kid put 2 sets off offroad lights on it and used those house wiring things to connect the wires. Going to fix that next and heat shrink it all.
Old Mar 24, 2013 | 11:49 PM
joshmopar's Avatar
joshmopar
The exhaust is also lacking in completeness.
