Rough Idle question
Old Mar 28, 2013 | 03:11 PM
ccd1977's Avatar
ccd1977
Default Rough Idle question
As some of you know I have been on this project to get better MPG, Performance, reliability and learn about my 2000 Dodge Ram 1500 5.9l 4x4.
So far, I have replaced the plenum, purchased 245/75/16 tires, complete tune-up and fluid swaps to amsoil, replaced IAC, TPS, pre-cat o2 and removed the CAT and single piped it from the stock y-pipe to a VX muffler. Spectre CAI.
There still one thing that is bugging me. A rough idle. I just filled up and put 87 octane and 2 bottles of techron in the tank. It said 1 bottle per 12 gal so I did two since my tank is 26 gal.
We'll, the idle is perfectly smooth now. Before it felt like it jumped alittle. Also, when left to idle in drive, the jumping would kind of make the truck jerk a little as it was going forward or backward. odd.
Not exactly sure what it could be. Any ideas?
Old Mar 28, 2013 | 04:01 PM
kejobe's Avatar
kejobe
If it idles fine now, what exactly are you asking? Could have been a partially clogged injector that is now clear.
Old Mar 28, 2013 | 04:20 PM
ccd1977's Avatar
ccd1977
Its only running fine because of the 2 bottles of techron. I am trying to find out if I have to always dump another $12 dollars of techron at every fillup.
In otherwords, what is the techron making up for that I should repair or replace so that my truck runs normal again?
I am fine with the clog removed but is there anything I can troubleshoot to ensure this is resolve and not just being covered up by the additive?
Old Mar 28, 2013 | 06:45 PM
zman17's Avatar
zman17
Retired Moderator - RIP
What brands did you buy? "replaced IAC, TPS, pre-cat o2" and did you remove the negative battery cable while replacing those items so the PCM could relearn the new values.
Old Mar 28, 2013 | 06:52 PM
gdstock's Avatar
gdstock
Hard to troubleshoot something that is not showing symptoms. An occassion bottle of Techron will not hurt anything, at least for a little while, maybe every other tank to make sure.
Chances are some crud from gas or gas tank. If you feel energetic, you could take the gas tank out and dump and clean it. See how much crud is in there.
Old Mar 28, 2013 | 07:13 PM
Ham Bone's Avatar
Ham Bone
What plugs, wires, cap and rotor? Are those all good?
An O2 sensor that is bosch will never work with these trucks. It will cause all sorts of problems
Old Mar 29, 2013 | 11:40 AM
ccd1977's Avatar
ccd1977
Everything for the tune up is OEM spec. Champion plugs, mopar rotor, etc. the O2 is NGK and TPS and IAC are BWD.
Update: the rough idle came back. Should I swap the MAF sensor?
Old Mar 29, 2013 | 11:42 AM
ccd1977's Avatar
ccd1977
I had both cables disconnected for about an hour. Turned key forward for about 10 sec and then started truck.
Old Mar 29, 2013 | 11:43 AM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
There is no MAF sensor.
There IS a MAP sensor.
You did clean the TB, right?
Old Mar 29, 2013 | 12:07 PM
ccd1977's Avatar
ccd1977
Yes. Map sensor is what I meant. I did clean the TB but did not replace the MAP.
