tranny interchange?
Hey guys need some help I got a 96 ram 2500 2wd 360 trans went out and my buddy gave me a 95 ram 318 trans an I read it won't work and there's other people sayin they've made it work was just wanderin what I had to do to make it Wrk if I could
It might work. It depends on what year the trans is that your friend gave you. If they are the same year IIRC all youll need to do is use your torque converter. There might be something else but Im not sure.
For starters we need to know the year of the trans though. Then we can go from there.
Thanx and ok anyone help can I just change the overdrive part or somethin i can't reallyafford a tranny other than the one I got
Trending Topics
Check the connectors on the side of the trans. Do they look the same. I hear that 96 was a mid-year change so you may get lucky.
The key to modifying to change will be VB compatibility. If the VB from one will swap into the other, then it should work. But I have not compared the VBs to each other and do not know if they are interchangeable or not. If it was me, I would be doing such comparison. But I can't afford to go buy an older VB to compare (if someone wanted to ship one, I would gladly do such comparison....)
(on another note, dang computer updated itself to newer IE, and spell check works here automatically! and annoying Caddy ads are not showing!)
