transmission issues
Old Apr 1, 2013 | 10:08 PM
Bambambravo's Avatar
Bambambravo
Sorry that was sarcastic. I pulled the plugs and re-gaped them checked everything. NO oil in the manifold no nothing. Come on 143K and nothing wrong. I have had this girl since 98. Everything is right on.
Old Apr 1, 2013 | 10:35 PM
moe7404's Avatar
moe7404
heres an EXTERNAL filter goes in the coolant line. most mopars are 3/8 tubing, but check yours. allso the return line goes in the rear fitting on the left side of trany. note the info that comes with the filter to know the direction to install.
man o man i about forgot yes its a cut & past sorry. __________________
after you clean the trans. add this to your*chrysler*trans. an external fluid filter
1. go to auto-zone. get 2210, its called a power steering filter, but it is for transs to. it is for 3/8 tubing. by (magna-fine) be sure to use high pressure hose. Reff:http://www.magnafilter.com.au/magna-fine.html*
2. for other sizes wix 58964 5/16 tube size reff:http://www.wixfilters.com/filterlook...sionfilter.asp
